Question about Xerox Phaser 7700 Laser Printer
Phaser 860 error"replace paper tray "
I replaced paper tray with new one. Also replaced right side I/O board and main logic. I used a scope and verified the switch was working to the logic. What else can it be?
    Scholar:
  • 141 Answers
Missing plug in tray on right side of tray. Top hole. Replacement plug can be gotten from xerox parts or inktechnologies.
Posted on Aug 05, 2009
  • Anonymous Aug 05, 2009
    On the right side of the tray, there are 3 rectangular holes. The "plug" goes in the top hole but, if it came out, it probably won't stay in. I've taped a piece of sheet metal in the hold before to get by. You can buy the part for a few bucks from xerox or inktechnologies. There is a lot of pressure on this plug so it takes something pretty strong to hold.
Anonymous
SOURCE:
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
How do I replace a Transfix Assembly
There should be a door on the right side of the printer. Replace the maintenance kit and clean the waste ink tray.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Apr 14, 2012 | Xerox Phaser® 860, 8200 Standard Capacity...
We are getting an error that says Change MP Feeder C5 on our Dell M5200. It will not print.
use the right arrow go to paper menu scroll to the right to paper source select if it is set to mp tray reset it to tray one. if its set to tray 1. check the side of the paper drawer to make sure the paper size snap in plate is in place. if these things are good replace the paper size selection pcb located in behind the logic pack
Jul 21, 2011 | Dell M5200n Laser Printer
Error code 6500
That error is an error processing on the main logic board, Canon suggests you replace the main logic pcb.
Aug 24, 2009 | Canon Pixma MP450 All-In-One InkJet...
Upper Paper Tray light flashing as if not all the way when it is.
Remove the paper tray.
On the right side you will see Three (3) holes
the plastic piece you found when in the bottom hole.
Since it is broken it will no longer snap into place.
Make your self fom either plastic or cardboard, a piece that will cover the bottom hole but not so big that it will block the hole above it.
Then using a good stiff tape (eloectical or duck) paste the piece over the hole, making sure you don't block the hole above it, or any other part of the machine.
I have taken a plastic knife cut to size and superglued it in.
If all else fails you can order that plastic piece that broke from Xerox. It's called a paper size sensor. about $5.00 for the part and about $10.00 for shipping.
Good luck
Luan
Jun 21, 2009 | Tektronix Phaser 860 Thermal Printer
Why is this tekronix 860 printer kept flashing error message saying missing upper tray. However, all trays are intact. It looks like a sensor issue
Tektronix printer paper trays, I seem to recall that there's a plastic key that fits on the right side of the paper tray. It's a little plastic piece that just clips in on the right side of the paper tray. Sounds like it's missing
May 18, 2009 | Tektronix Phaser 860 Thermal Printer
Phaser 860 Printer posting a paper jam at start up.
Sounds like printhead needs replacement.
Moving these printers without cool down is known to destroy printheads and of course wax goes everywhere and then everything else fails.Think about replacement
Jul 02, 2008 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8200 false "Replace Paper Tray" message
I've had a similar problem with a client's 8200 printer, and looking at the right hand side of the tray someone had previously put some tape over the topmost 'slot' (above where the green slider goes across).
I put some new tape over the top slot and the 'replace paper tray' message went away.
Admittedly, the tape gets pushed in so I don't know how long it will be before the tape gets dislodged and the error re-appears.
The printer is well out of warranty and they don't want to pay anything to get it fixed... so this solution is fine with them.
Hope this helps someone else out there :-)
Jul 02, 2008 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 7700 Laser Printer Logo
145 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
