SOURCE: While playing a game, my
If holding down the power button for 10 seconds (theoretically, try holding it down for ages and be patient) doesn't reset your device, you may have to wait for the battery to run flat, then try the reset procedure again.
Hope this helps,
Alistair
SOURCE: i am trying to upgrade
Good day. I''m afraid you might have accidentally got the Operating System of your Samsung Tab corrupted. Im referring to your firmware. Usually if the firmware upgrade failed you need to retry it until it be successful. If you restart it or discontinue the process it will cause your Samsung Tab to be corrupted resulting into failure of the boot up process. You might need to contact samsung tech support for this or bring your equipment to the nearest center. They might need to check the software install and usually their software specialist will fix it for you. Sorry for what happen with your tab but i know the samsung repair center can fix it for you. Hope this information will be helpful to you. Have a great day.
Testimonial: "Thanks for your immediate response regarding my problem. more power to fixya....."
SOURCE: Gateway M1300 tablet pc will not charge in the
Will the tablet operate on the docking station (or power cord) without the battery in place?
If not, the power circuit on the tablet motherboard is broken.
online shopping
SOURCE: My galaxy tablet was fine
You can damage the battery but it is very rare to actually do that. What you need to do is plug it in to the wall charger and leave it alone over night. At that point it should be just fine. it will actually start to show some signs of life after a few hours but don't be tempted to do anything wih it. it will first show a charge light or something after maybe 40 minutes if it is a faster charger.
If it shows no life the next day then you can try charging again but at this point you may hae a problem that requires either a battery replacement or warrenty. The battery has a microcontroller on it and when the battey gets real low they do not behave that well and typically you get the stone dead brick behaviour. And most people do not let it charge long enough to get it working. It is possible that there are other problems but those are usually moore serious and require replacement of the unit. The battery can be replaced but requires the etire case to be disassembled.
So charge it then check your warrenty and it may need serious repairs or to be replaced. If it is out of warrenty then you need to be careful on the cost verses replaceemn
SOURCE: no power
I had the same problem! It's not your charger, it's the tablet.
Most likely, the soddering came apart on the inside of the tablet, on the part that connects the charging port with some important wires. You can either take the cover off and fix it, but if it's like mine, it'll just come apart again.
This is what i did: plug in the tablet, and cross the cord from the right across the screen, to the left, and make sure it's tight. I use a binder clip to make sure it stays and charges.
Now try powering it up....that should work :)
