As it starts to feed...the left side of the feeder pulls the paper...but only the left side (my right facing the printer) pulls and of course, a paper jam occurs.
1> Open the sheet feeder cover and pull out the paper support.
Set paper, aligning the right edge of the paper to the cover guide with the paper's print side facing up.
Pinch and slide the paper guide to the paper's left side.
Note: Make sure to set paper lengthwise. Setting Credit Card sized paper long-side down by mistake may cause a paper jam.
Pull down the paper output tray supporting with both hands.
Pull out the extension completely.
Ensure that the Power lamp and the Auto Sheet Feeder lamp light.
Note: If the Cassette lamp lights, press the Paper Feed switch to light the Auto Sheet Feeder lamp.
If the Auto Sheet Feeder lamp does not light even after pressing the Paper Feed switch, Paper Source in the printer driver may be set to the setting other than Paper Feed Switch.
exactly the same
started out of no where
cleaning did the rollers did not help
I don't see any foreign objects
I have the same problem. Paper pulls to one side every time it starts to print. The roller is on the side that side.
My canon cp 200 only prints on the left side of paper
Nothing on the right side
When paper is loaded into feeder & you click print the paper jams ?
