Advice needed on a Bosch tumble dryer drying and anti crease/end lights flashing machine won't do anything
SOURCE: Bosch Nexxt 500 Electric Dryer: lint filter light goes on even though it does not need emptying
call bosch. they are having problems with one of the sensor in that dryer. they try to fix it but in my experiance they end up having to swap out the dryer
SOURCE: Bosch WTA3200GB/01 not completing drying cycle
It could be that it needs delinting, check the filter and the vent hose, remove the hose and put your hand up the channel and remove any lint, also check any other vents etc.
SOURCE: Bosch Tumble Dryer Filter Light
Helenhjb, there is a couple of things I can think of that can cause this. The filter is one. The mesh on the filter is extremely fine, so get a steady stream of water running, then put the filter under the water. If the water doesn't run straight thru, then wash the filter with detergent until the water does run straight thru. If this works fine, then your issue may be that the door switch is set too far back and when you do heavy loads, the laundry pushes on the door and shuts down the dryer. On the Bosch, any time you open the door during the cycle, it will flash the lint filter lamp. The only other thing I know of usually has an E:01 flashing on the display is restricted vent. Hope this helps.
SOURCE: hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
SOURCE: Hi,there is no heat coming from my Bosch Tumble Dryer
USUALLY A FAULTY THERMOSTAT OR HEATER ELEMENT ASSEMBLY
