Runs fine.. but won's spin on the spin cycle. agitates fine - I hear the motor going when spin cycle is engaged, but tub doesn't move.
Sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
Hi Mike, Great advice -- thanks for answering questions. I have a Kenmore top loader washing machine (model #110.22922100). The machine has worked very well, but recently we noticed that it sometimes did not spin. Then more recently, it fills, agitates, but stops partway through the wash cycle; just no spin, no drain. I bypassed the lid switch and it now does everything except spin. When it is moving through spin during the cycle, it seems to make all the right sounds, but the drum does not spin. In addition to a lid switch could this be a bad clutch or something wrong inside the gearcase? Thanks in advance for your thoughts.
motor runs, agitator doesn't move
the washer motor turns when you place on spin cycle but it makes a clickling sound and tub does noy engage
Spin cycle won't work
IT WON'T SPIN AND SMELL SLIGHT BURNING ODOR.
Motor runs, spin cycle does not spin.
the motor runs,but washer does not spin,belt is fine
washer tub wont spin
Motor is running as would if it were going through cycle but no movement
