Question about Sony BRAVIA KDL-40V2000 40 in. LCD Television
My tv is not switching on
Sony Bravia LCD tv won't switch on after a power failure. The LCD is flashing 5 times
  • dtlunz Apr 04, 2009
    Thanks
    I turned the power off for an hour and when I turned it back on it was working again
  • 16 Answers
It sounds like you had a power surge and the five blinks indicates that the video is not working. Unfortunately, it could be a number of things and a TV troubleshooter will have to go through the process of ruling out a problem and then considering the next problem.
Posted on Apr 04, 2009
6ya staff
SOURCE:
What can cause the sony bravia to switch on then off immediately.
6 flahes indicates a panel error possibly the backlight controller
Jan 31, 2014 | Sony BRAVIA KLV-40BX400 MULTISYSTEM LCD TV...
SONY LCD KDL-S40A12U SWITCHES OFF BY ITSELF
There may be a "Power saving" feature on the TV. Check in set-up and adjust time for auto shut off.
Jan 02, 2018 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Bravia KLV-40S200A LCD TV standby indicator blinks 5 times
Here is a link to the service manual--
http://www.scribd.com/doc/46056922/KLV-23S200A-and-Other
Page 11 explains the error codes--unless you are a tech with a meter etc it will be a shop repair.
A lot of good info including taking set apart correctly.
"abnormal power"
SD TECH
Jun 02, 2012 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Tv Bravia won't switch on for days, when on only white light and sound no pictures. Help
I think fault is in electrolyte capacitor.You should check the supply volt of cathode & all relative component of RGB input.
Jan 12, 2012 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
My Sony bravia kdl55hx800 lcd 3d tv won't turn on
try unplugging your t.v for a few minutes, then plug it back in. if it continues check your owners manual or google your issue. this might be the red flash of death. hopefully unplugging it works. good luck!
May 18, 2011 | Sony Televison & Video
Sony Bravia 46" The standby light flashes four
If tv model number is KDL-46S2000 then 4 times blinking standby light indicates back light failure problem in your tv.
Check/ replace back light inverter boards to solve its problem.
Thanks.
Dec 29, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Standby Indicator flashes red 6 times between 2 second intervals
My TV (Sony Bravia LCD KLV-32S310A) goes of after 20 seconds when it is switched on. The standby indicator then flashes (red) five (5) times then there is a two seconds break followed by another six flashes then two seconds break etc. What might have caaused this and what should i do?
Apr 13, 2009 | Sony Televison & Video
Sony BRAVIA KDL-40V2000 40 in. LCD Television Logo
656 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
