My Jenn Air refrig model # JCD2389GES is not cooling on the refrigerator side but is fine on the freezer side. This happened two months ago for two days then it was fine when I came home one night. I do not know where the damper is nor the computer board; help please.Thanks, My freezer is only working in the bottom portion and the refrigerator is not working at all. It is a side by side JCD2389GES. Seems this problem is happening a lot right now......
SOURCE: JennAir #JCD2389GES not cooling refrig at all.
I believe I solved my own problem. First, I defrosted the coils on the freezer side. This is done by turning off power to the refrigerator and using a hair drier to defronst. This takes about 20 minutes. To open the panels, unscrew the top two hex head screws just slightly. Then unscrew the next lower two hex head screws all the way and remove two panels revealing the frosted coils and the fan. It is easy to unscrew these using a screwdriver-type wrench. As the defrosting takes only a short time, I did not have to throw away any food. We have this same refrigerator in two houses, main house and vacation house, and I have used this method a couple of times on each refrigerator. The problem arises when, in warm weather, someone leaves the door open. One time it happened because a cardboard case of 12 oz sodas was preventing the door from shutting all the way. For that particular box, which is used in CocaCola products, you have to put the back of the box over the top of the shelf ridge; otherwise the box protrudes a bit too much in the front.
The above method did not work completely the last time I tried it. There was a warm spot in the middle of the rifrigerator side while the freezer side worked okay. To fix this new problem, after checking all coolness settings, I removed the assembly in the top of the refrigerator side--the control temperature control unit. The temperature control assmembly is mechanical and consists of just two levers that control the flow of air from a vent in the upper left corner of the refrigerator side. (My unit has the freezer on the right hand side.) The levers (for refrigerator temperature and freezer temperature) just open and close the vent. Another vent on the left middle of the refrigerator side controls flow to the middle. I had already opened this. When I loosened the temperature control assembly (four hex-head screws and two Phillips-head screws), I discovered that a piece of styrofoam had lodged in the air passageway between the freezer section and the refrigerator section. I removed this.
Unfortunately, I inadvertently broke off a plastic tab holding the canopy that covers the temperature control assembly. This caused me to do a lot of swearing. Nevertheless, I overcame the problem by purchasing a small shelf support that screws into the rear panel of the refrigerator. These are available on-line or from an appliance store. To avoid breaking off the tab, gently pull the canopy forward to allow the tabs on each (rear) side to be disengaged through two rectangular holes in the canopy. Gently work the tabs through these two holes.
After working on the canopy for awhile, I was afraid that the freezer coils may have gathered some ice. If so, I would have to re-defrost these. All was okay though.
One more thing: be sure that there is room for air to flow near the top shelf of the refrigerator. Stacking up too many things on that shelf deflects the airflow. When trying to get the refrigerator side working correctly, I removed everything from this top shelf. Cooling was perfect, so I added a few items to the top shelf, and everything continued to work just right.
Yet another thing: I figured out that the noise I had noticed came from the filter bottle that had outlived its usefulness. Rather than buy another filter bottle, I just ordered two dummy filters. I have given up on the actual filters because they cost $50 apiece and last for about four months. I can't taste the difference either in Los Gatos California, or Tahoe City, California. Of course, I had thrown away the dummy filters for my two refrigerators, but I was glad to see that these can be ordered on-line.
Well guess what. Jenn Air / Maytag now has this issue as a recall. So just call them and tell them the fridge is not cooling. They will schedule a recall service appointment. Do be sure they schedule it as a "recall" service appointment or you will be charged.
That sure beats pulling out the hair dryer every time it happens!
Service number is 1-800-462-9824
Good luck
