Posted on Apr 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Speaker problem my speakers are CREATIVE.they stopped after internet was put in my computer.in control panel it says there is no mixer device.i downloaded the mixer device but still it says ther is no mixer device.please help to make my speakers work again.
  • neerajprasad Apr 04, 2009
    the option on the right bottom screen just stopped appearing a few days ago.what do i do
pvc73
Level 2:
  • Expert 95 Answers
  • Posted on Apr 04, 2009
pvc73
Expert
Level 2:
Answers
95
Questions
0
Helped
23894
Points
249
Chk the right bottom of your screen for speaker symbol and check its not in mute and volume min position.
  • pvc73 Apr 04, 2009
    right click my computer, properties, device manager. check creative sound is there or not. if not..remove your sound card after switching off your pc and work . after one time boot and work switch off. plug your sound card and restart. it will found new hardware and put the cd when asked. hope it will work
My speakers just for some unknown reason aren't working.The remote control won't light up anymore
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
if you don't have the drivers you will need to download them
http://download.cnet.com/%7Bvalue=http://www.download.com/creative-labs-sound-blaster/3000-2120_4-10005159.html http://download.cnet.com/%7Bvalue=http://www.download.com/creative-sound-blaster-audigy/3000-2120_4-10198811.html http://download.cnet.com/%7Bvalue=http://www.download.com/creative-labs-sound-blaster/3000-2120_4-10022925.html
This hardware (creative sound blaster ct4650) is not work properly
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
hope this helps if you dont have the drivers
http://download.cnet.com/%7Bvalue=http://www.download.com/creative-labs-sound-blaster/3000-2120_4-10005159.html http://download.cnet.com/%7Bvalue=http://www.download.com/creative-sound-blaster-audigy/3000-2120_4-10198811.html http://download.cnet.com/%7Bvalue=http://www.download.com/creative-labs-sound-blaster/3000-2120_4-10022925.html hope one of these will help you
2answers
I've lost my Creative SBS 230 sound driver. pls send the driver coz i'm not hearing any sound from my desktop pc.
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
My speakers were working for 3 years, all was ok, but suddenly I deleted something, and they stopped to work!
also
hope this helps
Creative Inspire M5300 center speaker does not produce any sound
also
hope this helps
My speakers just suddenly stopped working its like theres no more power going through it, I've tried unplugging it and it still won't work. What should I do?
also
hope this helps
1helpful
I open the volume control, it says: There are no active mixer devices available. To install mixer devices, go to Control Panel, ... wht should i do
You need to install the sound device driver. Go into the device manager and verify it's installed. If it's missing reinstall it.
I am using a creative speaker. bass speaker is working well except for the small ones. is it shortwired or grounded? volume adjustment is also not working. only 1 small speaker is working but still...
navigate to control panel, select sound and audio devices. select advanced the volume control appears then set the balance to be at the center the on the other advanced option, select desktop stereo speakers. thanks.
I have 5.1 creative speaker system..but only two speakers are working
Go to Control Panel | Sound and Audio Devices | Advance (On Speaker settings) | Selects Your speaker Configuration.
If not work, check the Sound Card Software for properties.
1helpful
2answers
No sound from rear speakers Creative t6100
Try this:
Go to Control Panel >> Sounds and Audio Devices. Click on Advanced button under Speaker Settings and for Speaker Setup select 5.1 surround sound speakers from the options. Click Apply >> Ok and then check.
 Grubhead
Grubhead
SmartAviator
SmartAviator
