Question about Sony DVP-NS50P DVD Player
I have a Sony DVP-FX870 player. I have sound but no picture whatsoever. How can I fix this problem?
6ya staff
SOURCE:
Billy Rogers
  • 3 Answers
SOURCE: unlock region code on Sony CD/DVD Player DVP-NS57P
I don't have a solution, but I know that the one about "press Display, Top Menu, Clear, Power" doesn't work.
Posted on Oct 12, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Sony CD/DVD Player DVP-NS50P not playing my avi files DVD+RW
You need to convert avi files to dvd format before burning, otherwise the player won't recognize them. Google "avi to dvd" and you'll find a number of free or pay programs that will do the conversion for you.
Posted on Nov 19, 2008
ABRsvcs
  • 4234 Answers
SOURCE: sony player dvp-cx850d won't read cd or dvds. need to reset
This is not a problem that a reset will resolve. If you can gain access to the lens, try cleaning the lens using a cotton swab and alcohol. If that does not resolve the problem, the spindle motor may be defective. This is the motor that turns the disc. Once a disc is recognized as being loaded, the disc is spun up. If it does not get to speed fast enough, it will fail to read.
The bottom line is that without seeing the unit, I can not state exactly which scenerio you have here.
If the cleaning does not resolve the problem, I would suggest you request a detailed estimate from an authorized Sony service center.
Dan
Posted on Mar 10, 2009
tthekraut
Robert Dahmen
  • 374 Answers
SOURCE: I just purchased a Sony
Try to go under the settings in the dvd player. Be sure all the setting are set up according to your TV.
Sometimes if you dont have it set to N. American standards it can output like that. Be sure its set to "NTSC" if you live in N. America or Japan. If you live in Europe be sure its set to "PAL".
Let me know If this is not a issue in comments and I will help you further but I think this is it.
Posted on Mar 18, 2010
Paul Hutchinson
  • 909 Answers
SOURCE: How do I unlock my Sony DVP - NS330 player, bought
Codes for-
Sony DVP-NS300, Sony DVP-NS305, Sony DVP-NS400D, Sony DVP-NS700, Sony DVP-S330, Sony DVP-S335, Sony DVP-S360, Sony DVP-S336, Sony DVP-S525D, Sony DVP-S530D, Sony DVP-S535D, Sony DVP-S536D, Sony DVP-S725D, Sony DVP-S735D
Turn on the unit with the remote controller, Wait until "no disc" appears in the unit's display. Press the keys: PAUSE, 3, 1, 4, 1, 5, 9. And "CODE" will appear in the display. Press the number key that corresponds to the disc zone you want to play within the next 5 seconds:0: All regions / 1: Region#1 / 2: R#2/... and so on. Then, within 5 seconds, press: PAUSE, POWER... and voilà. If you don't have good results, disconnect the equipment and repeat.
Or
Put your player in standby mode and then enter: [[0] [ENTER] Default Default region code [1] [ENTER] or [UP] [ENTER] Region 1 [2] [ENTER] or [RIGHT] [ENTER] Region 2 [3] [ENTER] or [DOWN] [ENTER] Region 3 [4] [ENTER] or [LEFT] [ENTER] Region 4 [5] [ENTER] or [TITLE] [ENTER] Region 5 [6] [ENTER] or [DVDMENU] [ENTER] Region 6 [7] [ENTER] or [RETURN] [ENTER] Region 7 [8] [ENTER] or [DISPLAY] [ENTER] Region 8
Or
Put player into standby modes by pressing power button on remote control. Then press Title button. Press Clear button. Press Power button.
Yours is not listed but these may be worth a go.
or try http://www.haldigital.com/hp/dvd.htm
Posted on May 15, 2010
On my Sony DVD player I get sound but no picture
What kind of TV is it connected to / .Please check on the front panel of the DVD player if the Progressive light is on. If it is disable it and your picture will come back
Mar 10, 2011 | Sony DVP-FX820 DVD Player
Sony ns-355 cannot play dvd-r,dvd-rw. CD-read
The dvd laser is dead. The one that reads cd is still functioning.
Aug 19, 2010 | Sony DVP-NS355 DVD Player
Our DVP-FX820 DVD player is 16 months old. You can hear the sound when it plays but can't see a picture.
Please try adjusting the backlight. If the issue persists, try resetting the player. To reset the Portable DVD Player, remove the battery of the DVD Player, then reconnect it after 1 minute and check if it helps. If the issue still persists, then the player requires service.
you can get the unit serviced at:
https://eservice.sony.com/webrma/web/index.do
Jul 21, 2010 | Sony DVP-FX810 Portable DVD Player
Volume but no picture
Take the bottom off and check the connector to the screen if your warranty is void anyways you can't make it worse I hear it works loose will try this on ours next time
Jun 28, 2010 | Sony DVP-FX810 Portable DVD Player
I just purchased a Sony CD/DVD player, model #DVP-SR200P. I assume that I've hooked everything up correctly. I get sound and picture. But, the picture is in black & white. What am I doing wrong? Is...
Mar 18, 2010 | Sony DVP-SR200P DVD Player
Pictures taken from sony digital camera (6 Mega pixel) are not clearly seen on SONY DVP FX720. Is there any settings we need to do to get good quality?
change the format eg 640 x 480 to a higher resolution ...a good quality uses about 250kb per picture most jpegs use 50kb to save space
a really good picture can use 500kb.
May 15, 2009 | Sony DVP-FX720 Portable DVD Player
Dvd dvp-ns425p picture no sound
Comcast installed the wrong cables ie. red,green,blue vs. yellow white red.
Thanks for your timely response,
Catherine
Dec 15, 2008 | Sony DVP-NS425P DVD Player
Sony DVP-NS50P DVD Player Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
