I've had this Asko dishwasher for a year and half and when I went to start it last night, I pressed the power on button like normal and nothing lit up. I went and checked my breaker box and nothing had been tripped. I still have power to my garbage disposal, so I'm thinking it's something internal to the dishwasher. What should I do?
SOURCE: DW trips cicuit breaker
I have seen a lot of these older dishwasher break the wires running up to the timer. the break right near the bottom of the door where they flex when you open and close it. I would turn of the power, remove all the torx screws along the inside edges of the door, as well as the 2 on the bottom edge of the door facing up (you cant see them, just gotta feel around for them) and loosen the 2 on the top of the door near the latch ( so you can tilt the control panel out to remove the outer door) follow the wires from the timer down to the bottom of the door and see if any are broken or missing insulation. If not, take the bottom panel of the dishwasher as well and locate the 2 terminals hooked to the heater and check them with an ohmeter to see if they are grounded to the frame of the dishwasher. the dishwasher may be doing a heated rinse just before the dry cycle even though you have low temperature and no heated dry selected, so the problem may still be the heater. Good Luck!
SOURCE: ASKO Overfill protection tripped
Remove the backpanel of the machine, and look if there is water at the bottom of the machine. If so, use a towel or so to dry up the water. This should solve the prob.
SOURCE: Asko will not take in water so will not run.
remove bottom panel shop vac water from bottom tray fan dry shop vac sewer drain
SOURCE: Our Asko dishwasher will not shut off when we open
Welcome to fixya.
Based on your description and trusting it is indeed an Asko 1796, I'd suspect you have a door switch "accuator" sticking ( control pin as identified by Asko. pin part #80 575 42, switch part # 80 554 73 ).
This has been a random occurrence with Asko dishwasher's since they went to this design around 1994 or so. If the dishwasher doesn't stop when you open the door as you stated, here's a possible remedy you can try on your own.
Make sure the unit is off first. **Turn the breaker off at your home service panel before attempting any service suggested here on 'fixya"...safety first"
This procedure I'm going to suggest can be done easiest and more accurately by removing the control panel for better access as well as to visually inspect other component.
It can also be done without removing the panels by identifying the small round "pin" in the the door latch channel ( where the latch goes into the door when closed )...i.e.
...with the aid of a small screwdriver, tooth-pick, ear swab etc. add some vasiline or grease to the top of the pin working it in via pushing the pin up & down...I recommend removing the panels though.
To do this... Open the door and along the top you'll see "T20" torx head screws. Remove just the screws for the console/control panel, you must also be careful as the edges of these panels are sharp ( auto-mechanics protective gloves are good for this ).
Once off you can see the micro-switch and the small "pin" I was referring to earlier much easier.
Tilt the entire panel towards you slightly, just enough to work with ( careful not to undo any wires, or take pictures as you go ).
Apply some grease or silicone lube to the shaft of the pin/accuator and work it in really thoroughly. I find it easier to remove the plastic cover & micro-switch out of it`s bractket to allow a little room to work
i.e.
...careful not to let the plastic pin fall out. Where I pointed my finger in the image below is where to apply the lubricant.
Re-attach the control panel and you can test it before itstalling all the screws.
Let me know if you require further assistance.
Thanks for coming to fixya, please take a moment to rate the help you received. Good luck.
Regards,
Macmarkus :)
SOURCE: ASKO 1555 dishwasher won't run.
Welcome to FixYa.
Based on your description " The anti flood device motor won\'t stop running but we\'ve removed all the water " It is likely nothing very serious.
The flashing lights are directly related with overfill scenarios for Asko dishwashers of this era...DW95.5, meaning the control is indicating an overfill has been detected. Whether the unit has actually overfilled or not remains to be seen.
In the event it has, the outlet/drain pump motor is automatically turned on via either the pressure switch or a float in the base if sensing an overfill and removing water from inside the dishwasher will do nothing to resolve this error, but you can...
**before proceeding turn the dishwasher power off via the home breaker panel, or unplug it from the wall if that is possible...most are hard wired to the home electrical...safety first**
The first thing to do is remove the toe panel/kick plate and inspect the base for water. If water is present, with the aid of a sponge, towels, or a wet-dry shop vacuum, absorb the water from the base.
If the unit works fine after resetting the power/breaker it can likely be chalked up to a drain back-up or obstruction in the drain hose or pump.
If not, there are a couple of other possibilities that I'd focus on.
**again insure power to the unit is off**
The first is the float and subsequently, float switch. If you've removed the service panel at the bottom, or toe plate, you need to locate the float and it's switch. It will be located directly behind where your main electrical junction is...
i.e.
Once you've located the float behind the main connection plate, you should see something like this image below,
i.e.
With the aid of a long screwdriver or if you can reach it, move the float up and down and listen closely for the switch to "click", indicating it is indeed functioning.
Restore power again, and see if this resolves the issue, if not try this next...
The pressure switch too can cause all the lights to flash. It is the component which controls the normal fill level and the overfill detection...pre float activation. The float is primarily the last ditch safety to notify the user in the event of a overflow, back-flow, or leak underneath the unit to service or call for service to the unit.
It too is located under the machine and is mounted to the sump well assembly as shown, the large arrow indicates the switch while the small is the hose.
i.e.
The issue is possibly just the hose going to the switch is clogged with debris such as dirt, detergent buildup etc and will be remedied by blowing it out.
The best way to do this is to remove this hose at the switch in the location indicated above, be very careful as to not break the hose off with the part of the switch inside, they can be delicate.
I typically work it loose with a tiny screw driver gently working it away from the switch. Once removed, pour a small amount of hot water, white vinegar or "CLR" through the sump from within the tub...or you can try blowing it through with "lung power".
The other end of the hose is located at the back of the sump well and is quite vulnerable to blockages over time due to detergents, dirt, and such.
This is the location...do not break this or you will need to replace the entire sump well...no fun.
Large arrow is pointing back to pressure switch, small indicates connection to sump well, sorry for the poor quality...it's hard to get in there with a camera phone, ha ha !
i.e.
That's almost the extent of the possible causes of this error. Of course it could be the pressure switch has failed, the float switch has failed or ultimately the control has failed, but not likely.
This attachment below is also a retrofit tip from Asko regarding changes made to the pressure switch on the early DW95 series machines. you can identify if yours is this type by looking for the small white suppressor in the pressure switch...if yours doesn't have it you may want to change it while your at this repair.
Available at "repairclinic.com" for about $45USD.
Hope this helps move you forward, or even better resolves the issue altogether. Let me know of course, I will help you move further if necessary.
Good luck.
Regards,
Macmarkus :)
