Well my camera has not been used in a while but now when i got to power it up it goes to the screen to set the time and date but none of the buttons work. the mode wheel works but I cant get passed the time and date page. I cant take any pictures. I love the camera and really do not want to buy another one. What should I do
Yea but is that something that could be replaced or do I need to buy a whole new camera??? When you say circut board it sounds like something that cant be replaced?? Thanks for the commentYea but is that something that could be replaced or do I need to buy a whole new camera??? When you say circut board it sounds like something that cant be replaced?? Thanks for the comment
You can't post conmments that contain an email address.
I had an open DSC-W50 in my basement, so I just took a look at it. It can be replaced fairly easily. It has a connector, and one screw holding it in place. It can be accessed, after the rear casing of the camera is removed. Let me know if I can help...perhaps a Google search on my user name? ;)I had an open DSC-W50 in my basement, so I just took a look at it. It can be replaced fairly easily. It has a connector, and one screw holding it in place. It can be accessed, after the rear casing of the camera is removed. Let me know if I can help...perhaps a Google search on my user name? ;)
To set the date and time stamp on pictures, Follow the given instructions: Setting Date and Time:
First of all set the exact and time if your camera:
Press the "Menu" button on the camera and use the right navigation button to choose the "Set Up" menu.
Scroll down to "Date/Time" and press the ""Func./Set" button. The set
date and time will appear on the screen, and the month unit will flash.
Adjust the month unit by pressing the up or down navigation buttons.
Move to the day unit by pressing the right navigation button. Use the
same instructions to adjust each unit of the date and time.Push the "Func./Set" button to save the time and date settings.
Setting Date Stamp on pictures:
Press the "Func./Set" button and select "Recording Pixels" and "Postcard". The camera is now set to "Postcard" mode.
Open the "Rec." menu by pressing the "Menu" button on the back of the camera.
Highlight "Date Stamp" by pressing the down navigation button.
Change the "Date Stamp" setting by pressing the right or left navigation
button. Your choices are "Off", "Date" or "Date/Time". Now, when you
take photographs the date or the date and time will appear on the
picture.
If
this solution helps you then your token of appreciation in the
form of Rating as Four Thumbs and a testimonial will be esteemed. Thanks you for using FixYa!
Taken from manual: SETTING THE TIME AND DATE You can set the time and date on the camera as long as the battery stays in the camera. Once the battery is removed the time and date settings will be lost: Symbol on LCD Screen Function When you see "dAt" on the screen, press SHUTTER button to set the time and date. Press POWER/MODE button to toggle from Y09 (2009) to Y30 (2030). Press SHUTTER to advance to next date setting. Press POWER/MODE button to toggle from 01 (January) to 12 (December). Press SHUTTER to advance to next date setting. Press POWER/MODE button to toggle from d01 (1st day of month) to d31 (31st day of month). Press SHUTTER to advance to next date setting. Press POWER/MODE button to toggle from H00 (12 a.m. military time) to H23 (11 p.m. military time). Press SHUTTER to advance to next date setting. Press POWER/MODE button to toggle from 00 (zero minutes) to 59 (59 minutes). Press SHUTTER to advance to next date setting. 1. Once you select the "minutes" setting and press the SHUTTER button, you will return to the SEt entrance for the settings menu. EXITING THE SETTINGS MENU When you see ESC on the screen, press the SHUTTER button to exit the SETTINGS MENU.
The date stamp only works in "Postcard" resolution. Press the Func Set button, then scroll down to the bottom to select postcard resolution.
Then press the menu button. The date time stamp selection should now work. Simply turn it on.
hi Some of those buttons work in combination with the two dials (i.e., setting ISO and white balance, etc.). Hold a buttin down and user the knobs simoultaneously. If this is not the issue, please describe specifically which buttons are not workin...
power button on to left(camera). press the display button until the mode screen appears. press the up or down arrows to select menu then press the center of the operation button Press the operation button again and execute highlites press oper button again it goes to setting 1.Press arrow up to others 2 press oper button again. arrow down to settingand press oper button again THis gives you the month,press again for day and so on . arrow up or down to change year and time.
The part where memory card went in is damaged like bent metal, you should buy new camera and be careful in the future putting in mem card the right way.
I finally figured it out!!! There is a button on the right-hand side of the camera, which switches it from normal mode to simple mode. Just press the button and everything goes back to the way it was...
Set date and time and camera should work. If camera asks to have date set everytime you take batteries out then the memory 3 volt battery is flat ... replace.
