SOURCE: Changed router ip now unable to connect...
hi, i have the same problem that cannot connect to router after i changed ip address... i set my network connection to ip address 192.168.254.2 & subnet mask 255.255.255.0 & default gateway to 192.168.254.254... i can ping ip address 192.168.254.254 but cannot get into the web browser... i cant go back the router configuration page... pls. help... my router is zhone 6218...
SOURCE: zhone 6218 driver
The manufacturer won't have your installation CD because that process is exclusive to your ISP. Check your ISP's website to see if they release their setup software online or contact them to get the required CD.
SOURCE: i cant log into the admin account on 192.168.1.1
press the RESET button on the back of the router and hold it in for 30 seconds. Use a pin. Once you have reset the router it will default to a generic user name and password. The default user and passords are admin admin or user user
If you still have trouble call support
Telephone (North America) 877-ZHONE20
SOURCE: Need login and password for a Zhone router/modem
If you got your Zhone modem from consolidated communications then the login is admin pass is cciadmin
SOURCE: Need to change the NAT setting on my Zhone 6218
try these simple steps...
connect your computer to one of the LAN(wired) ports of router...
check the ip address and default gateway of your local area connection
through control panel > network connections.... if you get the ip
adress in the range of dlink router then try going to start > run
> type "cmd" and hit enter >command prompt will appear... in
command prompt type this
start iexplore(default gateway address) and hit enter...you will see the settings page of your modem.... go ahead and disable firewall and enable dmz for your ip address... also forward the ports that are necessary for your gaming device...
