Nokia 3230 Logo
Posted on Sep 03, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blank white display on Nokia 3230
I am geting blank display on my nokia 3230 , phone is fuuly functional but as display is blank but its light up white when press any Keys Initially this problem was on only screen saver startup , ( I was able to get proper display after restart and I was even manage to kill/stop screen saver) but Past to days its not helping with restart/reboot Its white blank display but phone is functional Kindly help/Guide me to fix it NOkia people are ...... , they not even able to dignose the same , your Valuable reply Awaited
  • 7 more comments
  • Anonymous Mar 04, 2008
    ya i hace face the problem that my nokia 3230 scerrn ger totaly white ie bkant
    what to do
  • poksi Mar 06, 2008
    yes i have the same problem...but at first there was a message "system error"... i tried to turn off the unit but when i tried to turn it on...only a blank white display appeared.
  • Anonymous Apr 07, 2008
    Its the same case here.. Mine was 2 years old..
    any idea on the cost of the display panel? Or should I change battery?
  • Anonymous Mar 09, 2009
    no diasplay apper
  • shughri Mar 15, 2009
    the same problem
  • Anonymous Mar 29, 2009
    having lots of software problems so wanted to flash mobile
  • Anonymous Apr 07, 2009
    Hi friends,
    I have problem with my nokia 3230 - the display is not working (black screen). But when i turn on the phone the keypad light is working. When someone calls its ringing but the screen is still blank (black screen).
    can anybody help me ouut?
    what is price of new display card?
  • anop177chetr Apr 13, 2009
  • mir murad May 11, 2010
    nokia 3220 whait display
Anonymous
Level 3:
  • Master 4,889 Answers
  • Posted on Oct 09, 2007
Anonymous
Master
Level 3:
Answers
4889
Questions
8
Helped
1512479
Points
14106
This is a major fault, screen gets blank white because of some problem in its display panel which is right behind the LCD screen. Rush to the nearest Nokia care centre and explain the problem to them.After the repair if you experience this problem again and your phone is within the warranty period you can demand a brand new box piece!
  • Anonymous May 11, 2010
    I do not have a magic wand to repair your panel remotely. If that was what you were expecting, I am sorry!
1helpful
Blank screen
The display circuit strip least probably is damaged or most probably is loose from the connector. in either way contact the local vendor to plug it back into the connector between screen n motherboard of the phone. it ll be fixed.
Feb 28, 2010 • Nokia 6600
Display problem
Its power strip problem Replace it.
Sep 23, 2009 • Nokia 3230
1helpful
2answers
NOKIA 3230 - 'Switch on' problem Hi, My nokia 3230 mobile got switched off on its own and I am unable to switch it on since few days. Even the logo "Nokia" is not appearing on switching the power switch....
Hi ,Try to charge your mobile with another same model battery, switch it on.. and keep it swiching on for five mins,, and try with your battery .. its really works.. this is all because your battery charge limit is gone under minimum
Nokia 3230 screen goes blank after a few minutes of turning on.
hello !
replace the LCD theres a posibilty of it being foulty , the IC on the lcd is damaged and please check the lcd socket on the MB .
Thank you
1helpful
the problem on it is the crystal IC on the display,, replace it
Only blank white screen is seen when i switch on the mobile?
Hi. It sounds like a faulty screen. Have a look here for a guide to replacing the screen and to buy the parts http://www.formymobile.co.uk/3230lcd.htm
2helpful
N72 white display
My N72 (Nokia) phone’s display shows blank when switched-ON. Blank in the sense means that the display lights are ON, but no images in the display. Sometime the dispay comes and goes. In addition, the phone is not ringing or can’t make calls. Can anybody help me?
1helpful
2answers
LCD screen went blank
to fix this problem is usualy simple, 90% of the time if you have a blank screen it is because the screen has come unplugged, open the casing of the phone and just plug the screen back into the circuit borad this should solve ur problem, please note this does not work if you have full white screen. hope this helps people with this problem.
Jul 28, 2008 • Nokia 3230
Top Nokia Computers & Internet Experts
k24674
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
