Sony KP-61V90 61" Rear Projection Television Logo
Anonymous Posted on Aug 08, 2013
My t.v. led is bling on timer and standby - Sony KP-61V90 61" Rear Projection Television
francoise cleofas
Level 3:
Genius:
  • Sony Master 2,432 Answers
  • Posted on Aug 09, 2013
francoise cleofas
Sony Master
Level 3:
Genius:
Answers
2432
Questions
0
Helped
298383
Points
6852
Tried to disconnect the ac supply to the tv for a while. then plug it again and power it on hope it will back to normal. you can use the remote control then turn off the timer.
tip
Error code by led indicator samsung SP67L6HX1X
<img src="mas_baz.jpg" /><br />There are three LED indicators. LAMP, TIMER, STANDBY/TEMP. Each Led or combination leds indicated problem.<br /> <ul> <li>LAMP blinking : The picture will automatically appear in about 15 seconds.</li> <li>TIMER and STANDBY/TEMP blinking : A cooling fan inside the set is not operating normally.</li> <li>LAMP and STANDBY/TEMP blinking : Lamp cover on the rear of the set is not properly shut.</li> <li>STANDBY/TEMP blinking : Check if the ventilation hole on the rear of the set is blocked, because if the inner temperature is too high, the power will shut off.</li> <li>All LED blinking : Lamp may be defective.<br /></li></ul>It takes about 30 seconds for the TV to warm up, so normal brightness may not appear immediately. The TV has a fan to keep the inside lamp from overheating. You'll occasionally hear it working.<br /><br /><br />
Standby/ Timer blings. TV will not turn on.
hello edshanklin!
your tv indicates power source failure, commonly some transistor or capacitor defective. please contact service for repair.
regards
Thanks for using FixYa - a 4 THUMBS UP rating is appreciated for answering your FREE question.
I have a Sony KDS-R50XBR1 that has no picture. When I turn on the TV, the green Power/Standby LED light blinks for about 30 seconds, then turns red and blinks five times. The Power/Standby LED repeats...
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen A2 slightly.
1helpful
Tv has power but will not turn on
Very vague but okay let me give you some reasons:
1. bad power supply
2. bad inverter voard
3. bad capacitor inside the power supply
4. burned out fuse.
These are common answers why your TV just is not turning on. You gave me no leway to work with like "my frount power led is red" or "my standby light is bling X times" Vague issues vague answers please od leave postive feedback and ratings for your vague answer today!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
WILL NOT POWER ON, STANDBY, LED, TIMER LIGHTS ARE BLINKING.
Check the capacitors on the power supply first. If any have domed tops or signs of leakage, replace them. I had two go bad on mine. Call electronics parts supply stores first as these are not your average capacitors.
Power led blinging went turn on
this could be becouse you have set a timer on the set check your timer settings
KP-41T15
On the pcb labeled (G) board look for location RY602
the replacment sony part number is # 1-755-018-11
this is the repair for stand by light blinking.
Thi is the repair for Power light blinging.
Q601, Q602 parts number(2sc4843)
r606 0.1ohm 1/2w also replace c604 and c605.
hope this helps,
regards,
daniel.
Repair inquiry
     According to the LED BLINKING there must be some problem that are given below:
Diagnosis item:  Video out abnormality detection
TIMER/STANDBY
Indicater
Number of blinks:
5 times
Supposed malfunction:  Video out, IC7101, 7201, 7301 and others in C board circuit.
Q510,516,524 (A board)
Condition:TIMER/STANDBY LED blinks approx. 30 seconds,
and then blinks for the self diagnosis.
Self-diagnosis
screen display,
Diagnosis item: Results:   5 : AKB 000
So, This was the result of 5 times led blinking.I would suggest you to please contact any expert or strongly recommend to contact any SONY SERVICE CENTRE for repair because it's not an easy job to rectify this problem. Hope you better understand my sayings.
Thank you for using fixya.
2helpful
2answers
Power comes on, red light flashes on timer/standby but no picture
Need the model number of your set and also how many times is the led blinking? Please respond to this same post
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
