SOURCE: Speaker Noise when volume turned down LTN226W Samsung
this is due to leakages in your internal circuit... this generally happens due to aging... the part which has suffered damage has to be found and replaced... but this part can be identified only physically testing the voltages and currents on the internal circuit...
SOURCE: Samsung flat screen T.V with sound problems.
Sounds like the issue is with the set top box of your cable or direct tv provider. Please swap that receiver for the equivalent or a more updated version.If the problem persists. Verify that all inputs on television is correct. It should match. Output of source( digital receiver,dvd player) to Input( television ). Make sure all is secure. Good luck
SOURCE: How do I connect my ps3 to the Samsung smart tv
For best performance I recommend you connect a HDMI cable from the PS3 to the HDMI input on your TV.
To display the PS3 you need to select the HDMI input on your TV.
SOURCE: Samsung LCD "keys locked"
Hey it taken me a few years to find a solution to this problem.
I also own a Samsung syncmaster 2032mw.
BTW you must hold / use the "Menu key on the side of the TV", as holding the remote key dosen't work!!
Many thanks dopeNL
