This is a front load washer and I need the repair manual
Manual for the HE2 and Duet Sport here:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
(give it time to download, big file)
The model number for the Kenmore HE2t front load washing machine is 11047571600. If you go to the Sears site for manuals and enter than number you can get the manual on line.
Hope that helps.
SOURCE: Kenmore HE2 front load washer. All cycle lights flashing plus spin and clothes clean lights on.
I'm sure this is probably too late, but hopefully it will help some else. I just had the same problem. First, unplug the power. Then take the lower front panel off and grabbed a bucket. Place the bucket under the large "plug" on your right. This is the drain. Slowly unscrew the drain plug, Hold your nose as it will probably smell. Allow the water and such to drain into the bucket. When you see the blob of wet lint drop into the bucket you will know why the machine refused to work. Make sure you clean the drain plug and screw it back in tightly. Put the lower panel back on and reconnect the power. I hope this resolves your issue.
SOURCE: My Kenmore HE2 Plus front load washer
See the following site for a manual and parts breakdown / list.
http://www.managemylife.com/mmh/owner_manuals/search?query=110.47511701
