Corrupted software [firmware]. A firmware update is necessary. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Suggest using Google to access a copy of the manual. Some units have a reset function, other are like a computer with an internal battery or reset button.
Easy fix...because you are using VGA screen ...you need to push pretty fast on your remote the following ( do this twice) fast....push. Freeze. View. Return. That should fix it. If twice oes not fix it keep doing it...it will work.
Good luck.
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
