There are several performance issues you may encounter with
your Protron PLTV-37C LCD television.
Some problems include the television not turning on, issues
with the TV's picture and issues with the TV's sound.
Depending on the type of problem you encounter, there are
several options available to you to solve it.
Power Issues
Check the TV's main power cord. If it is not plugged in or
is loose, securely plug it in to an electrical socket.
Unplug the television and plug it in to another electrical
socket.
If the one it is plugged in to currently is bad, the
television does not receive power.
Try turning the television on with the remote.
If that does not work, try turning the television on with
the power button on the TV's front panel.
If that works, then remove the battery cover from the
remote.
Remove the current batteries and replace them with fresh
batteries.
Picture Issues
Check the video cables.
If they are loose or disconnected, securely connect them.
Adjust the television's brightness.
If the brightness is set too dark, images on the screen are
extremely difficult to see.
Check the power indicator on the front panel of the
television.
If it is red, the
television is in power-saving mode.
Simply press any button on the remote to bring the
television out of power-saving mode.
Audio Issues
Check the audio cables. If they are loose or disconnected,
securely reconnect them.
Turn to different channels and adjust the volume.
It is possible that some channels are coming in quieter than
others.
Access the audio options from the main menu. Check what
audio setting the TV is at.
If it is set to "Mono," change it to
"Stereo."
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=dde1880d298054849d8c8adc90514f40&modelid=22971545&q=Proton+CS-37
Specifications
for Proton CS-37 / PS-47
Summary of picture settings
The following picture settings can be confi gured. Depending on the
format of the picture source, some picture settings are not available.
• [Auto Picture]: Sets all picture settings to the factory default.
• [Brightness]: Adjusts the intensity and details of dark areas.
• [Contrast]: Adjusts the intensity of bright areas, keeping dark areas
unchanged.
• [Color]: Adjusts color saturation.
• [Tint]: Adjusts the color balance in an image.
• [Sharpness]: Adjusts the level of sharpness in image details.
• [Color Temperature]: To set the color temperature to [Normal],
[Warm] or [Cool].
Summary of sound settings
The following sound settings can be confi gured. Depending on the
sound source, some sound settings are not available.
• [Auto Sound]: Sets all sound settings to the factory default.
• [Equalizer]: Adjusts individual sound frequencies.
• [Virtual Surround Sound]: This selects the modes for more spatial
or surround sound reproduction.
• [Auto Volume Leveling]: Reduces sudden changes in volume, for
example, during commercials or when switching channels. Select
[On] or [Off].
• [TV Speakers]: Select [On] or [Off], or output sound to an
EasyLink compliant device. When [Speakers EasyLink] is selected,
the TV speakers are disabled and TV sound outputs to the speakers
of the compatible EasyLink compliant device. Adjust the volume
using the unit's remote control.
OK.
Basic Picture Control- Displays the five slider controls for adjusting
the way the picture looks.
Contrast Adjusts the difference between the light and dark areas
of the picture.
Color Adjusts- the richness of the color
Tint Adjusts the balance between the red and green levels
Black Level Adjusts the brightness of the picture
. Sharpness Adjusts the crispness of edges in the picture.
appear. You can choose either Yes or No. If you save the settings as a
Personal Picture Preset, the TV will store the settings so you can reselect
them easily if someone changes the settings.
Picture Presets Displays- a choice list that lets you select one of three
preset picture settings: Bright Lighting, Normal Lighting, Soft Lighting
or Personal Picture Preset. Choose the setting that is best for your
viewing environment.
Auto Color Displays- a choice list that lets you turn on the feature that
automatically corrects the color of the picture. (This is especially useful
for tracking realistic flesh tone colors as you switch from channel to
channel.) Choose On or Off, depending on your preference.
Color Warmth Displays- a choice list that lets you set one of three
automatic color adjustments: Cool for a more blue palette of picture
colors; Normal; and Warm for a more red palette of picture colors. The
warm setting corresponds to the National Television Standards
Committee (NTSC) standard of 6500?K.
Video Noise Reduction Displays- a choice list that lets you turn on the
feature that automatically reduces noise from the picture. Audiovariable
enables the TV to automatically adjust noise reduction level;
off turns off noise reduction feature; on-fixed sets a fixed level of noise
reduction.
