Note : Please try unlocking your Nokia 6020 mobile phone only once using the steps given below with the Nokia 6020 unlock code you get from our unlocking tool. If it does not work, do not try again as it may get your Nokia 6020 permanently locked. Do not enter any wrong unlock codes on your Nokia 6020 mobile phone. If you enter over a certain amount of wrong unlock codes on your mobile phone, your Nokia 6020 phone may get permanently locked and sometimes become unusable.
1 - Switch on your Nokia 6020 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6020.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6020 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6020 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6020
try to check if it is charging if yes that mean your device has broken internal power button and you need to show some official repairer to solder new one, if also not charging that mean your device has a battery problem or software problem. for further help post comments.
Switch off the Nokia 6020 phone. Remove the battery for 30 minutes.
Reinsert the battery and switch on the Nokia 6020 phone. Enter the
default code 12345 or 00000. Your Nokia 6020 phone will be unlocked
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, *
Star key, no. 3 key on keypad and then press the power on/off to
swtich on the phone. Remember, do not let go the 3 press and
hold
keys until you see a formatting word screen show! 2. After a
few
minutes when the Full phone formatting completed, your phone
will
back to original system and factory settting.
There can be many reasons for that. The software can be corrupt which is causing the phone's data to unload and be switched off. The battery may be out of charge. Thus the phone is not getting power to switch on. The phone battery may have caught moisture. Thus the moisture is causing the phone's charge to drain off and not consuming power when supplied. The phone may have somehow undergone some hardware fault. I told this because there are many cases in which the phone's internal mechanism gets broken when it falls down or hits something. Try contacting NSC ( Nokia Service Center ). They will give you the exact cause for it and surely repair it and get it new again !
