SOURCE: frigidaire front load washer problems
most likely something is stuck in the pump. it could also be that you are not using high effiency detergent.
SOURCE: Frigidare Front Loading Washer model# FWT645RHSO
check out the drain pump if drain pump is blocked up water will not get away quick enough and stop machine from spinning
if that is clear
turn bowl by hand and if you get a runble noise then the main bearings are gone
that will need dismantle and replacement or new machine
SOURCE: Frigidaire front load washer won't drain or spin
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
SOURCE: Frigidare Model # FTF2140FS1 problems with spin cycle
not a very sturdy pedestal, front loaders need concret solid base
SOURCE: ATF6000ES front load washer won't spin during regular cycle.
clogged filter will cause this error code. I have the same washer and the filter located inside the rubber boot attached to the pump was full of junk. there was enough room for water to get thru but not enough for full volume. clean it out and it should work. note : its a pain to get the boot back on so be ready and take it slow. this worked for me.
