My washer does not seem to get the clothes clean. After several wash cycles, there is still a sudsy residue in the wash tub during the rinse cycle.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean.
Next run your washer with 2 cups of bleach, hot water. After it starts agitating stop the washer & let it remain for 2 hours. Then continue the wash.
Try using powders for 'front loaders'
Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
Take out the inserts and rinse them and the drawer thoroughly.
Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
