Icemaker is making ice but ice/water won't come thru the door...can you help. How does one thaw out the auger if indeed it is frozen?
I'm having the same problem and I've identified that the ice auger is no longer being turned by the rear drive coupling b/c the rear drive coupling is slipping on its axis or axel. There is a nut and some sort of metal clip there but I haven't figure out how to removed it yet.
I'm having the same problem and I've identified that the ice auger is no longer being turned by the rear drive coupling b/c the rear drive coupling is slipping on its axis or axel. There is a nut and some sort of metal clip there but I haven't figure out how to removed it yet. The water not coming from the door dispenser may be linked to the electronic valve in the bottom rear access panel area or possibly a blocked line. ID the valve by actuating the water dispenser and listen if you can hear the valve selenoid. You can remove the water lines at the valve to trouble shoot if the valve is opening. that way you can determine if it is a blocked line or just the valve or something else. [email protected]
Use a hairbdryer
THE ICE IS STILL GETTING STUCK IN THE DOOR WHERE THE FLAPPER IS...
Icemaker does not make ice. Water works but no ice. It seems there is ice in the maker but it does not eject the ice. Suggestions?
it's making ice but can't get the ice to drop, you can hear it running and that round thing in the bucket turns. what is the problem.
does it need a new auger motor
Defrost water drain on floor
Water on floor
Water on floor
