SOURCE: hotpoint wma54 washing machine
Being fairly mechanically adept - I tried this on my old Hotpoint WMA31 -- it took around 90 mins to get the drum out (virtually everything had to come out) and 1- mins to split it in two - then another 30 mins to knock the bearings out. I then ruined one new bearing trying to knock rather than pull it in and had to order a second set - then whatever I tried I could not get the drum fully back on the spindle (which was rather pitted) so ended up scrapping it !
As an aid to putting it back together I took 32 digital photos of different stages of getting the drum out so that is a measure of complexity...
SOURCE: noisy on spin cycle LG WM1832CW
this is joyce
Go to lg.com and download your manuel put in your model #
thanks
joyce
SOURCE: LG Intellowasher 7kg, Model WD-8074FHB - noisy spin cycle
You are right!
Bearings have to be replaced. Replace with the same type and design. All the bearings connected to the washer center shaft has to be replaced at the same time with new set.
Replace the water seals also connected to this. Check the shaft where the bearing sits, for any abrasions or metal damage.
Check the bearing housing also. While carrying out these repairs check the drive belt also. If needed replace it.
If you are happy with the machine outer body and other aspects repair it and re-use it.
Testimonial: "Thanks for the quick reply Ambari, that's exactly what I wanted to know. Atleast I'll some idea if the repair bloke is pulling a swifty. Cheers"
SOURCE: Fisher and paykel GW611 excellence top loader wont
Check Out Of Balance switch This will prevent spinning and programme from advancing
To set your Favorite Cycle
1. Press the POWER Button.
2. Press the FAVORITE cycle button. Hold down for 4 seconds until you hear two quick beeps and the Favorite light flashes.
3. Select your favorite cycle (eg Regular or Delicate).
4. Select the wash options (eg soak, time saver). Use Advance if you want part of a cycle (eg spin only).
5. Press FAVORITE again to store your favorite cycle.
Note: Your Ecosmart will remember your favorite cycle, or any other cycle that has been customized, even when unplugged from the wall. It is not possible to program a delayed start into the Favorite cycle.
http://www.fisherpaykel.com/customercare/userguide/index.cfm
