How do I remove HDD from HDD Caddy on Panasonic ToughBook CF-73
The caddy on all Panasonic Toughbooks are
held together by pressure.
I use several paperclips (unfolded) to wedge
between the side of the caddy and the small holes
which are located around the caddy. There are two
along the right side, one in the front and one in the
back and two along the left side.
I usually start with the far left side and work my way
to the back, then to the far right side, slowly prying
with pressure a few millimeters at a time.
Finally I go to the right front, then the front and
at last to the left front, almost in a circle.
It is a little tricky and may require several attempts,
but the caddy will come apart. Please try to remember
how the cable attaches to you can re-attach after
you change the hard drive.
Good Luck
