The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the time on the image, in the margins, or on the back.
SOURCE: how do i change the
Turn the Kodak's dial to "Capture" mode. This brings up the camera display. Press the "Program" button behind the dial. Press the "Down" button until "Date Stamp" is highlighted. Press the "OK" or "Set" button to access the date-stamp menu. Press the "Down" button to change the selection to "None." This removes the date stamp. Press "OK" to save the setting. Press "Program" to return to capture mode.
SOURCE: i have kodak Easy Share
In any mode, press the MENU button. Use up/down to highlight Setup (three horizontal sliders) and press OK. Use up/down to highlight "Date Stamp" and press OK. Make your choice and press OK.
SOURCE: How i can remove the
Press the MENU button. Use left/right to select Setup, then up/down to select "Date Stamp".
SOURCE: kodak easy share camerac 613
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date and/or time on the image, in the margins, or on the back.
