SOURCE: stihl string trimmer shaft viberation, how do you
Most of these type units only allow you to replace the entire shaft assembly. Have one myself and could not get just gearbox.
SOURCE: Looking for printable copy of owner's manual for
go to www. stihlusa.com
click on product instruction manuals (under chainsaw picture)
click on download or order manuals
scroll down to trimmer section and find your fs80 and fs 85
click on it and it should come up and be what you were looking for
SOURCE: pull cord is out and wont return. unable to crank stilh fs 45 we
Could be several things including a broken return spring. If you are not experienced with these springs please take it to a reputable shop to avoid any personal injury.
SOURCE: stihl fs 45 ignition problem no spark
Disconnect the small spade terminal wires from the coil itself and test for spark. If you do not have spark replace coil. If you do have spark check those small wires for insulation damage and grounding. If wires are OK check kill switch.
NOTE: DO NOT START MACHINE with small wires unplugged! Only test for spark.
SOURCE: Replacing trimmer line with blade for stihl fs 90r trimmer
If you bought the trimmer new there should be a rod about 6" long and 1/8" thick. Above the trimmer head below the trimmer gearbox there is a hole. You have to put the rod in that hole and turn the head until that locks it from turning.
From there you can screw the trimmer head off by hand, or a strap wrench if it's really tight. It may be left hand threads.
http://www.mediafire.com/download/fmfdwl...
http://www.mediafire.com/download/81djtq...
