First of all, you should not be using the internal memory. It's very small and is only there for a few test pictures when you first get the camera. Go out and get a memory card.
Does the camera say it's full even with the card out of the camera? If so, the camera is telling you the internal memory is full, not your memory card. The camera will not write to the card until you format the internal memory while the card is out of the camera.
Your camera is only supporting SD/MMC Cards (up to 1 GB)
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card. 1: Menu 2: Cam settings 3: Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
The Internal memory and SD card are different beasts. There is a certain value that alows pics to be taken without a memory card in situe. It is this part that is saying the memory is full Use settings to clear internal meory of photos or files being held. If this oersists even after yoiu have emptied the memory you will need to take it to a Kodak outlet
The cause and solution may include one of the following:
The camera internal memory or card is full. Transfer pictures to the computer, delete pictures from the camera, switch storage locations, or insert a memory card with available memory.
The camera processing memory is full. Wait, and resume picture taking when the light turns green.
The card is read-only. Change the storage location to internal memory or use a different card.
