If it were worth repairing, as a Sony agent, I would replace all of the capacitors and clean up the board then reset the mechanism and test.
Probably too old being 2001 vintage.
My SONY CCD-TRV57E isn't recording or any function.seem to be working. Bty ok. In view finder I'm getting "SP C:31:22" also a symbol like and inverted coathanger with a line thru it and a + sign on top.
This is already an issue with the hardware. There is a rubber bond inside the cassette that is no longer intact and needs to be replaced. Possible cause by repetition of single and old cassette tape and improper tape position.
sc-d353 got wet slightly the camera part is working but good tapes display eject sign and in the middle of the screen displays the eject symbol and ...r please help
the timing will be out of line, thats whats putting in shut-down mode. dis-engage the tape carriage from the running cogs and manually put it in eject mode, re-align the main cogs to their pointers. there should be one on the cogs and on the chassis to help you re-align then re-engage the carriage to its cog.
I think u are using pre recorde cassetts that were recorded on any other camcorder.. Samsung D363 supports ntsc not pal.... and the cassetts recorded on pal must have prob with ntsc based device... all u have to do is record cassette with the same and then test playback...
