Video Game Consoles & Games Logo
Posted on Apr 05, 2009
Black flag problem
How come every time I get black flagged and go through the pits, I have to continue going through the pits 6 or more times before it gets rid of the black flag? Book said I should only have to make 1 pass through when black flag.
Thomas Kimble
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Mar 01, 2010
Thomas Kimble
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
Helped
394
Points
5
You got to do under green flag. and u cant do it with your speeding.
My Honeywell pro series thermostat has a caution flag on the display. What does that mean?
Do you mean the alert flag (a triangle with an exclamation inside it) or a different symbol? The Alert flag will appear with another message on the screen. If it is time to replace the battery, you'll also see "BATT" to the left of the flag and a low battery icon somewhere along the top of the LCD screen. If the thermostat is set to alert you to change the HVAC system filter regularly, you'll see "REPL" to the left of the alert flag.
This is from the T4 Pro thermostat manual on pages 6 and 7. See https://forwardthinking.honeywellhome.com/assets/tseries/resources/install/T4%20Pro%20User%20Guide%20-%2033-00188EFS.pdf . The T6 Pro uses the same alert behavior.
I hope this helps.
Ineed blacklight tango down product key
Serial: http://fileups.net/1h9tg do a small surveyCHEAT CODES:
Al13nwa4re5acasE - Alienware Symbol
Alienwarec8pestU - Alienware Black Dog tags
AMD3afrUnap - VISION square tag (red)
4MDB4quprex - VISION square tag (blue)
AT1hAqup7Su - ATi square tag.
E3F6crAS5u - Grey/Orange Dog tags
Denek1Ju3aceH7 - Yellow Teddy Bear
Fam1tsuprusWe2e - Tag with ingraved-writing/picture.
Bl4ckl1ght2Ru7uS - Couldn't get to work.
Ch1pBLuS9PR - Blacklight logo chip.
Ch1p1GN1u0S - Lighting bolt chip.
Ch1pMMRSc0rp - Blacklight "W" logo chip.
Ch1p0RD3Ru02 - Order logo chip.
Ch1pZ0MB1Et7 - Zombie Studios logo chip.
H4rtBr34kerio4u - Pink Brass Knuckles.
SKULLCLUB9rAVaZ2 - blue skull square tag.
J4ceH4llstuFaCh4 - Couldn't get to work.
StormLion9rAVaZ2 - Dinosaur thingy??
St0rmLi0nB4qupre - Dinosaur thingy?? tag.
R4z3erzu8habuC - green and black tag.
UPGr0undWupraf4u - Black square tag with design.
UPGr0undv2FUDame - Black square tag with design.
AUS9eT5edru - Australian Flag
AUTF6crAS5u - Austria Flag
BELS7utHAsP - Belgium Flag(?)
CANfeprUtr5 - Canada Flag
DENdathe8HU - Denmark Flag
FINw3uthEfe - Finland Flag
FRApRUyUT4a - France Flag
GERtRE4a4eS - Germany Flag
HOKYeQuKuw3 - ???
INDs4u8RApr - India Flag
IRE8ruGejec - Ireland Flag
ITAQ7Swu9re - Italian Flag
JPNj7fazebR - Japanese Flag
KORpaphA9uK - Korean Flag
MEX5Usw2YAd - Mexico Flag
HOLb8e6UWuh - Holland Flag
NZLxut32eSA - New Zealand Flag
NOR3Waga8wa - Norweigien Flag
PORQ54aFrEY - ???
R41nB0wu7p3 - ???
RUS7rusteXe - ???
SINvuS8E2aC - ???
ESPChE4At5p - ???
SWEt2aPHutr - Sweden Flag
SWIsTE8tafU - ???
TAW8udukUP2 - ???
UKv4D3phed - United Kingdom Flag
USAM3spudre - United States Flag
How long to replace clutch in a 1998 mazda 626
For a 4 cylinder 2.0L engine flag time to remove and replace clutch 5.4hrs.
For a 6 cylinder 2.5L engine flag time to remove and replace clutch
6.3 hrs.
hope this was helpful for you.
The timer remains on all the time. I have to actually go out there and manually turn the timer off. I don't have a manual, so I don't know what the little red plastic flag amd the little black plastic flag...
The BLACK flag is for ON time.The RED flag is for OFF time. Set the Black flag into the rotating timer for the time of day you want the timers to turn ON and the Red flag for the time you want to turn the lights OFF. Once you have the flags in rotate the timer dial by hand and note when the lights go on and off. Adjust the flags as needed. Set the timer for the correct time of day and plug in. Also, you can check the Intermatic web site for additional information.
1helpful
Can't get to one flag on WII Fit Advanced Cycling - I can see the flag, it is near the flag that is at the end of the tunnel with sand. I can't get to it. When I get to the flag at the end of the...
on top of the hill, there is a flag that you have to get. if you look to the right, there is a tunnel, and then you have to go in there and then at the exit, it is a dead end sand pit. the flag is there.
1helpful
I have a lexmark x543 that always has the message "std bin full' when it is not.
if you look where the black rollers are on the out put bin top rear of the printer to the left there is a flag this is what causes that error. it is either sticking or broken. lift up on it and make sure it falls back freely if the flag is not damaged change the sensor. i have to to tell you 95% of the time the flag is sticking or broken. out of a few thousand repairs ive only had to change that sensor twice.the mount for that flag just clips into place it can be dislodged fairly easy check to make sure the mount is not loose
Unexpected message: 6B22
That is a pre heater fault.
Preheater exit sensor in unexpected state during fault.
Preheater exit sensor in unexpected state during stage.
  1. Check system grounds.
  2. Check the Drum Maintenance Kit NVRAM contacts during oiling for continuity.
  3. Check the waste tray.
  4. Replace the Preheater ( REP 2.0.17).
B2M
B2N
B2P
B2Q
The preheat flag tripped unexpectedly while picking paper from Tray 2.
The preheat flag tripped unexpectedly while picking paper from Tray 3.
The preheat flag tripped unexpectedly while picking paper from Tray 4.
The preheat flag tripped unexpectedly while picking paper from Tray 1.
  1. Test the Preheater Sensor using Service Diagnostics.
  2. Check system grounds.
B3M
B3N
B3P
B3Q
B3S
B3T
The preheat flag timed out waiting for the paper picked from Tray 2.
The preheat flag timed out waiting for the paper picked from Tray 3.
The preheat flag timed out waiting for the paper picked from Tray 4.
The preheat flag timed out waiting for the paper picked from Tray 1.
Preheater sensor timed out during stage.
6helpful
8answers
Phaser 7300 error message...
The problem is a crazy design in the printer itself! I've now found a reliable fix for this problem which is relatively easy to carry out. You will find the details of how to do it here :
www.michelsplace
Top EA Sports Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you an EA Sports Video Game Console and Game Expert? Answer questions, earn points and help others
