Mach Speed Trio Stealth G2 Tablet - Android 4.0 Ice Cream Sandwich, 7 Logo
A
Anonymous Posted on Aug 11, 2013
Trio stealth g2 just shows start up screen won't boot up
lloyd photo
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 04, 2014
lloyd photo
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1952
Points
My table resets up on ever boot , you have to renter all the info every time you boot it up, Trio G2 10in
When i turn it on it says trio stealth g2 and stays there and won't turn the rest of the way on.
Perhaps the HARD RESET PROCESS can help you, Merrill. I've posted my suggestion as to how it's done HERE. ( http://www.fixya.com/support/t25341481-trio_stealth_new_when_power_goes ) , so you may findt that information useful.
I've had good success with HARD RESETTING when trying to correct errors like forgotten password, or forgotten lock-patterns. However, I've had a Trio Stealth G2 that displayed the SAME problem as yours, Merrill, and it would NOT respond to ANY attempts at resetting. I tried every combination I could : pressing volume down (-) and power; volume UP (+) and power; volume UP & DOWN (+ AND -) and power. It refused to boot. But since the case and the screens were in great shape, I went on Ebay and bought a Trio with a cracked screen, swapped the motherboard from THAT tablet and it worked perfectly.
Final caution, though: ask the Ebay seller to guareantee the physical condition of the ports and other controls on the unit before you buy it. Remember you need a working motherboard.
Best of luck to you, Merrill!
How to fix trio stealth g2 stuck on boot ?
turn it off. if you can't then their is a reset button on the side where the charger is. Get a safety pin put it in the hole. You will know if you reset it. It will reboot. It won't effect your files or info. I hope this helps!
I have a Trio-Stealth G2-8 and turn on but the screen said @9 Dual Core and don't do anything else can somebody tell me how to fixed?
Its a common problem with tablets and not easy to fix.
Your tablet has a corrupt os and is caught in a boot loop.
There are fixes but not easy for a beginner.
Boot into recovery mode by pressing the power button and holding the down volume button in then select restore tablet from the recovery menu.
1helpful
2answers
How to reset a trio stealth g2
If you can power it on go into settings then backup and reset. This will reset tablet to the out of the box status. You will loose all of your data. If it will not power up, press power and volume up while booting till the screen comes on.Boot options will come up then reset. Be sure the tablet is fully charged.
My trio stealth g2 hype 4gb tablet will not go pass the trio stealth g2 logo it just freezes up what can i do
Have you tried my old trick of pressing the on/off button and at the same time, press the volume+ button. Sounds like you have a screen freeze. hope it helps.
LindaSView
2answers
How to restart a trio stealth G2
all that shows is trio stealth G2 when turned on it freezes I tried the reset button
Top Mach Speed Trio Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Mach Speed Trio Tablet and eReader Expert? Answer questions, earn points and help others
