My Variax 500 also had the same problem. Sound cut out when I plugged in with the power adaptor using the TRS cable. Resumed when I just play with batteries. I fixed it by disconnected all power sources, opening the cover at the back of the guitar, spray the circuit boards with CRC contact cleaner, wait until it's completely dry and reconnect the battery and power adaptor.
Not a solution but an input. This problem is truly random. You can play a whole gig and it's fine. Then plug it in the next day and it's gone in a minute. So...probably not the IC heating up thing...
mine cuts out suddenly and will only start again if I unplug the stereo cable from the guitar and plug it back in. but then it might only work for a few minutes before cutting out again. Sucks!
