Hi there, My washing machine is hotpoint WTL500 and it just stopped in the middle of a cycle and the door red light is blinking. Pls help out as i've tried to put it off and on severally without success.
SOURCE: Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
hold the start button for 5 seconds this should clear previous program. then select drain on your dial. press start as normal and machine will drain. if this does not work the only other remedy is with help, making sure the end of the drain hose is higher than drum at all times take machine outside, lean it back at 45 degrees agaist a wall with a towel or similar covering lid to stop scratching . working from underneath loosen the large jubillee clip that connects the drum to pump drain hose to the drum. As the drum is overfull there is no recepticle large enough to fit under so just let water just flow away. Dry every thing off. make sure you don't loose ping pong ball in filter and make sure filter is clear. refitting is reverse of removal
SOURCE: Washer door won't open (hotpoint first editon 800)
I have just had exactly the same problem. 10 seconds of washing, fuse blew, replaced it, cycle completed but now the door lock is stuck on. Like you I tried a new cycle but this has done nothing. In the end (and I'm not suggesting that this a remedy to the problem) I unplugged the machine - pulled the door handle til a gap appeared at the top of the door and forced it open by working a pair of scissors in to the gap and pulling. Of course as soon as I shut the door again and turned on the power the lock light came straight back on the and the door was locked tight. Sorry but this is the best I have come up with short of calling some one out.
SOURCE: hotpoint wma 50 flashing pre-wash
i had the same problem, the programmer inside the control panel had blown,
check the wiring hasnt pulled near the motor, sometimes an earth wire comes off apparently.
Try unplugging the unit and plug it back in. This may reset the controls.
SOURCE: My hotpoint washing machine wmf540 keeps flashing
It happened on our machine. The soloution to this for me was to take the lid off (two screws). Unplugged from mains. I found the connector to the door had vibrated off and was just hanging loose. Plugged it back in and it worked straight away.Door opens as normal.
Don't forget to look in the manual for how to get the door open in an emergency.
Thanks for your reply. The machine starts and after like 20-30 minutes of working, the door sign starts to blink and when the door is opened, the drum has to be rolled up from facing down before being opened. I hope u can help me. Thanks a lot....
