Panasonic Lumix DMC-FX01 Digital Camera Logo
Posted on Apr 05, 2009
When I zoom useing my panasonic lumix DMC-FX01 it turns off
When I use the telaphoto on the panasonic lumix DMC-FX01 it turns off and prompts me to turn it back on.
Anonymous
Level 1:
Problem Solver:
  • Contributor 18 Answers
  • Posted on Jul 13, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
18
Questions
Helped
11842
Points
33
Have you had problems when you turn it on and off from scratch before? It sounds like you have a problem with the lense extension. Now if you are lucky, it's just a bit of dirt in there and the best cure (I know, it sounds horrible) is to put the end of a shop-vac over the lense when it's closed and it will probably **** the obstruction out. If you are less lucky, the problem is with the gearing inside and in the middle of the luck-vs-effort range it could just have been bashed, in which case, you can try and push it back into alignment but be careful with it (he says, after he hit his last one with a large lump of wood to put it back).
Good luck :)
Panasonic DMC FX01 with new battery still won't turn on?
If your panasonic camera uses a panasonic battery and you try to use a different brand equivalent battery, some panasonics will not work. Could that be your problem?
3helpful
I bought a SDHC 4GB card and introduced in the camera. When turn on, came the message "memory error". What should I do?
Check your instructions, is a 4GB SDHC card compatible with your camera.
if you don't have a manual, just google "panasonic lumix dmc-fx01 manual" several options will appear.
Page 16 deals with card compatibility, it states that the maximum you can use is a 2GB Sd card, no mention of SDHC.
Lumix DMC-FX01 Buttons not working
Remove the card and battery. Clean the battery contacts inside camera with a cotton swab lightly dampened with rubbing alcohol. Be sure battery is charged. Press all buttons on camera. Insert card and then the battery. See if it works. If you can now get into the setup menu, you can do a reset from the menu.
Lost Lumix simple viewer C D for Panasonic Camera DMC FX01
If you are looking for drivers in that CD, click Panasonic Support and check drivers list of DMC-FX01 at bottom of page.
and if you need Software CD, please contact nearest Panasonic service center.
Panasonic lumix dmc-fx01 won't focus
See the post for the same camera: "Buttons stopped working": there is a small 2 position switch connected to the zoom button. In my camera the zoom switch was stuck in one of the extreme positions. You have to put it back in the middle an re-assemble.
sir, it's a mechanical lens movement problum this is repairable
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
