String gauge is a personal preference. I'll ask you this: what is your playing style? I see your picture and its a Jackson DK2M. One thing to remember is that the Floyd Rose usually needs adjusted with a different string gauge. With a Floyd, I recommend replacing one string at a time unless you are cleaning the neck with steel wool. If you are taking all the strings off at once and changing them all at once and not one after another, put a towel under the back end of the Floyd Rose so it does not tilt back and mar the finish. Jackson usually installs 9's on their guitars, but this is too light in my opinion.
The pickups...there is a screw on each end of the pickup to adjust the pickups up and down. Raiseing them will get you more output but more noise and feedback. Lowering them will get you a more mellow sound. I keep mine no less than 3/16 to 1/8" from the strings.
Bridge adjustment...Floyd Rose trems are tricky little animals. They have small allen screws to raise the saddles up and down. Raise the bridge just enough to keep the strings from buzzing excessively and as long as they don't make a buzzing sound thru you amp, its nothing to worry about.
Send me a message if you have any more questions. With a Floyd Rose, it would not hurt to go consult your favorite guitar shop or a friend with a Floyd equipt guitar to see them work on them.
