SOURCE: Hoover steam vac will not turn on.
did you drop the handle on the floor? sounds like you may have a loose prong on the on/off switch take it apart and look to see
SOURCE: shut off
From your description, you problem sounds like it could be an electrial one, not very hard to diagnose, but some dis-assembly is required. you would have to remove the hood, motor cover, turbine just to get to the motor. I would check the carbon brushes for contact on the armature first. the other things to check would be the cord but the back lower half of the handle would need to be taken apart. I would highly recommend to bring it in for an estimate only, most should do one for a minimal fee or deposit.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
SOURCE: Hoover Windtunnel shuts down after 15 minutes
Might be that its not exausting enough heat & stutting its self down..
Try cleaning all the filters & the hepa filter..
This will increase air flow & maybe fix the issue..
Hope this helps !!
rate me good ;o)
