Hi, is there a way i can delete the some songs from my iphone?
In case it does not work with iTunes, try this alterative solution
http://www.iphone-without-itunes.com/delete-iphone-songs.php
It's great, because you don't even need to have iTunes installed on your computer.
John
You should be able to go into itunes and delete the songs, then sync your iphone again. If that doesn't help then I would go into the apple store and see why not. you can also just call apple for support for free if you are an at&t subscriber good luck
If you have thousands of songs in iPhone and want to get off music from iPhone, you have easy methods to do that. If you only want to delete several songs from iPhone, you can go to the music app in your iPhone, and tap the song from right to left, then you'll see the red "Delete" button. After tapping the delete button, you will move the song from iPhone. However, you can only get music off iPhone one by one with this method.
Another method is using iTunes to get the unwanted music off iPhone. You should turn off the auto-sync at first. you need to plug iPhone into computer via the USB cable, and then sync selected songs with iPhone. By syncing with iTunes, you're also able to delete music from iPhone. When syncing with iTunes, the non-purchased music files in iPhone will be erased.
If you want to delete multiple music files from iPhone without erasing the non-purchased music files in iPhone or deleting the songs in iTunes library, you can check out the iPhone transfer software.
http://www.leawo.org/tutorial/how-to-delete-multiple-songs-from-iphone.html
It's no longer possible to delete songs from iPhone in iOS7. To remove music:
1) Find a PC/Mac
2) Install iTunes if it is not installed
3) Connect your device
4) Tell your device to trust the computer if it asks
5) Switch over to the device view
6) Browse to your music on the device
7) Delete it
Getting music off isn't as easy as putting it on but the swipe gesture now goes back in menus on which you can get a new interface of iPhone Data Eraser.
How to Delete Songs from iPhone
iPhone Data Eraser Erase Data Safely Protect Personal Privacy
I found a way! You can't swipe to delete songs from iPhone., but if you swipe right to left (not left to right) on individual tracks or videos, that works. It's a pain in the *** if you have a lot of music but it's better than nothing. How to Delete Songs from iPhone
iPhone Data Eraser Clean up Data Safeguard for Ultimate Privacy...
SOURCE: Hi I wanted to delete photos from my Iphone so I
Find your solution from the list,
Apple Iphone Smartphone
Codes:
Software & Hardware Problems
Find Your Solutions for other Apple Products:
Apple Iphone 3G
Apple iPod Touch Digital Media Player
thank you very much for the tips. but i thinks it is locked by the the other computer i went to download some of the applications and songs. the songs are all there but they're all on blue shade.
