I am new to this job and for some reason when I replaced the typewriter ribbon, and hit the keys, the wrong key sypes
I have this typewriter also. after replacing the ribbon and print wheel you have to press the (CODE) & (=) keys. This will align itself. I recently had to replace the print wheel and referred to the manual. Works like a charm.
Linda, Depending on what make and model you have it could be several things. The newer TW's use a print wheel which has to home itself each time the power is turned on. This tells the print motor how far to turn for the correct letter. Make sure there is no debris and everything is seated properly... platen, print wheel, etc. Once again, this depends a lot on what kind of TW you have. MM85
I have a smith corona word smith model #KA13 I took the ribbon out and it stopped typing please help
how do you install the printwheel?
how to changed correction tapes brother typewriter
Sears 2000 series electric typewriter has a key that is stuck. How do I fix this also where can I ge a new ribbon?
