Whirlpool LSR5132PQ Top Load Washer Logo
Posted on Apr 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Leaking water washing machine -lxr9245eq1
Sometimes it leaks water during water coming into machine. sometimes it may go through whole cycle and doesn't leak. now it starting to leak more often. water in back of machine and on sides of machine. water stays on rim of tub by bleach disperner.
Anonymous
Level 3:
  • Master 686 Answers
  • Posted on Apr 06, 2009
Anonymous
Master
Level 3:
Answers
686
Questions
0
Helped
249140
Points
1652
Sounds like a levelin problem check it in both directions and post back, also post model number TY
1helpful
Water leaking on fast spin
hi Eamon.
this is what i found from the internet.
Washing machine leaks on spin Last updated on February 6th, 2017
Sometimes a washing machine leaks on spin, but not before. If this is the case, either it's going into spin with too much water inside, or something may only be leaking under the pressure and tub movement caused by spinning.
If you can see water running out of the soap drawer during spin it's probably gone into spin without pumping the water away properly. If it wasn't pumping water out at all it would not go into spin, but a partial obstruction can reduce the flow enough to allow a spin with the water unable to escape fast enough. This causes water to be forced up into the drawer or out of the steam vent at the back. If you suspect this check the last section of this article - Washer leaks from drawer
If water is coming from underneath when it spins then it's more likely to be caused by something leaking only under pressure. Check the door seal all around inside for slits and small holes, especially higher up, which may only open up and let water out when the washer is bouncing around on spin.
Other possible causes are hoses inside the machine which have small holes which open up during spin or which leak where they connect to the tub under spin conditions. These type of leaks often leave tell-tale rust or dry detergent marks. After that there could be a crack or small hole high up in the plastic outer tub which only gets exposed to water when it's forced around the tub during spin.
You are looking for something that is moving and allowing water out when the tub bounces around under load, or something high letting water out when it gets thrashed around the top half of the machine on spin. If you can't see anything obvious get a washing machine engineer
More articles about leaking washing machines Why does my washing machine leak only during the spin cycle
and if you want to read up on some more then try this link.
washing machine water leaking on fast spin cycle Google Search
Washing machine leaks during spin and drain cycle
If the leak is still present after you replace the hoses , you may need to get a new water pump ( cheap part ) it is probably leaking , it removes the dirty water from the washer during spin and rinse cycle . hope this helps
Leaking MAH2400AW washing machine
Does the machine only leak on start up? or during the whole cycle? when machine not operating does it still leak?
1helpful
Whilst wash on, water leaks from the underneath of washing machine. but cant see where it is coming from
if the water is leaking during the fill cycle when the detergent is being added from the drawer
ensure the draw is clear, if too much deturget rests has blocked the vent then water maybe running out on the inside.
if the problem is happening during the wash cycle this indicates a leak on your drum, ensure your door seal is intact and not leaking.
if the problem is during pumping, ensure that the pump is not causing a problem
maybe open the bottom vent and ensure the cover is seated properly and pump is clear.
also check the outlet pipe is not blocked or leaking and water is running back on the outside of the outlet pipe and under the machine
I hope this was useful.
Puddling on floor during high speed spin cycle
you have a leak in your outlet hose normally caused by rubbing on the drum barrel / repair with tape or replace whole hose but this brand of wASHER ITS VERY HARD TO REPLACE IF DONT KNOW HOW TO
Water coming out of the botton during spin cycle
Take the bottom panel off the waher, put water in the machine, and watch to see where it is leaking. If you don't see a leak during the regular cycle, put the machine in drain and spin mode, and watch for leaks there. You should find your leak during one of these cycles so you will know what part you need.
My washer is spewing water everywhere sometime during its cycle. The floor is soaked! It seems to be coming from the soap dispenser area. I cleaned the dispenser really well but still water everywhere.
The only way to determine where the problem lies is to take off as many covers as possible then run your usual wash cycle. The problem could be a leaking or blocked pipe or a rubber seal that leaks etc etc. Have somebody in the know open up your machine to determine where the leak comes from.
Best wishes,
Graemevm
WATER IS COMING OUT FROM THE BOTTOM OF THE WASHING MACHINE ONCE THE WASHING HAS STOPPED, IT DOES NOT LEAK DURING CYCLE AND IT SPINS AND DRAINS FINE..
i would inspect both the hoses on the pump
no leak during cycle is explained because water is moving through them to fast to leak when the machine settles it starts to leak
1helpful
Washing machine
If water is leaking only during the times when it is supposed to be coming in , then the first places to check are at the hose connections and the hoses themselves. If it continues to leak after the water stops coming in , then you have to look at the drain connection and finally at the drum seal.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
