The Proscan 19LA25Q came with a remote originally. Unless the IR receiver has failed, it should work with a universal remote. (Note: if the TV is newer than the remote (or released less than 6 months before the remote was programmed), the remote codes for your TV may not be included.) Since the code lists on universal remotes do vary depending on the age and model, please give more information than just the brand. GE remotes usually have a version code label in the battery compartment. This version code is needed to look up the correct code lists. Some GE universal remote built by Jasco codes are here: https://byjasco.com/support/ge-universal-remote-codes.
The Proscan 19LA25Q was probably built in 2007, since there are reviews from 2007. That was also the year when this size TV had to have an ATSC tuner. So if your remotes were programmed before July 2007, they may not be compatible. Some of the current Proscan TVs probably use the same parts as some Sylvania, RCA and Curtis TVs.The 19LA25Q was warranted by On Corporation which has control of the RCA brand now. However, I don't know when they bought the label.
Here is the list of universal remote codes given by PROSCAN in your owners manual. I hope this helps you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST For Universal Remote Control brands listed below, please use accompanying Proscan codes and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to operate Proscan model. Proscan codes for Sony TV=8003,8012 Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216 Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
Found these codes on the website for PROSCAN. www.oncorpus.com, for youmodel television.I hope this help you with your problem. UNIVERSALREMOTE CONTROL CODE LIST For Universal Remote Control brands listed below, please use accompanying Proscan codes and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to operate Proscan model. Proscan codes for Sony TV=8003,8012 Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216 Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
Found these codes on the website for PROSCAN. www.oncorpus.com, for you model television.I hope this help you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST For Universal Remote Control brands listed below, please use accompanying Proscan codes and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to operate Proscan model. Proscan codes for Sony TV=8003,8012 Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216 Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
I used the remote control code of "69" for Thompson which makes GE & RCA according to another post. This worked to program the remote of my GO Video DVD-VCR for the TV
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
