check the IP address for the device by reading the manual and setup same range of IP in your computer and then browser the device IP in you browser. u will get username /password and do the rest by following the screens.
The router is not connected to the internet. Check the cable from the router to the modem - try a new cable. Reboot both devices. Connect a computer directly to the modem to make certain you have internet.
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
this happened to me, it needs charging, make sure the blackberry symbol on the lead is facing up, putting it in upside down moves the little tab inside the housing stopping you from charging properly, if it is a bit loose realign the tab with a thin nail file carefully just a touch then push the lead in symbol side up and switch on give it time it should charge..
Verify that your laptop can connect to the D-Link. Then on the laptop, in the search window enter CMD. In that window enter " ping 8.8.8.8" If you get a response - actually 5, then your likely issue on the D-Link is DHCP settings. Enter "close" to close the black CMD screen.
A response proves that you have Internet access but only to numeric addresses. Use the supplied disk or instruction manual to log into the D-Link and update the settings. If you get no response, go through the full setup procedure on the D-Link.
This can occur when the wireless adapter in the computer has trouble connecting to the wireless router. It
may not get an IP address from the router or the wireless adapter
encryption setting didn't get an the encryption authentication from the
router. In this case right click on the wireless adapter on the Task
bar and click Repair. This will make the router re-issue an IP address
and authenticate the adapter's encryption setting.
I might advise you to reconfigure the DI-514 Wireless Router, Access the IP address 192.168.0.1 using the Internet browser and configure as Dynamic IP address. You got a red light because the router is not configure yet or no Internet connection from your provider.
i) on the bottom-right-coner of computer desktop(system tray) you will computer like(double)icon showing the connectivity to internet, see whether it is showing a red corss(X) symbol on it if it is so then there is no internet connectivity, other wise you will see a movement or graphic on the icon, if it is so then there is internet connectivity.
ii) if there is red corss(X) symbol on it try remove the internet connection(wire) and replace it and if you use an internet service provider which require id, password try to enter them after installing sofware provided by internet service provider.
iii) otherwise contact ur internet service provide to make sure internet connection is working perfectly from his side.... and he would assist in better what would be the problem....
iv) try to change you browser, switch some other browser like opera, firefox, .......not Internet Explorer....
I have the same warning light (and beeping) on my M6P09D2A. However, I could not get any water to come out of the drain tube. How did you get the water out??
