So what is the correct fix. I plan to replace the defrost heater and thermostat. Any thing else? How difficult is this job?So what is the correct fix. I plan to replace the defrost heater and thermostat. Any thing else? How difficult is this job?
You can't post conmments that contain an email address.
the compressor is not running,you need to buy a new ptc overload/relay and replace the defective one on the compressor,it unplugs off the side of the compressor,its what starts and runs the compressor
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp. The problem could be the electronic control if you have one or the mechanical linkages.
