Hi ive got some speakers to hook up to my computer but when i plug them in i cant get sound from them am i doing something wrong? Thanks.
Which operating system ??.....
If your computer came with a
motherboard disc the sound drivers could be on it
Click start control panel administrative tools computer management device
manager scroll to sound video and game controllers you might see a yellow
question exclamation mark? ! or a red X Right click to reinstall drivers.
Click start control panel sounds and
audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio
you will find 3 drop down lists make sure you have selected the correct speaker
settings.
Click start control panel sounds and audio devices select advanced there might
be a tick in the mute box untick it
If his does not fix the problem
audio devices you can adjust the volume there also select speaker.
volume you can change your settings there you can also tick in the box place
icon in taskbar for any further volume control settings you will need to right
click on the speaker volume icon system select adjust volume.
audio volume advanced speakers select the appropriate speakers from the drop
down list or navigate to the device manager scroll to system devices + to
expand system speaker right click properties then select use this device
(enable).
The speaker plug/outlets is usually
at the back of the computer or if its a laptop on the side.
You will have to open up the computer to check the lead attached to the
rear of the input plug make
sure the connection is good with no dust as dust causes static electricity.
Clean your computer of dust
using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU
central processing unit.
Dust causes static to build up in a computer
http://download.cnet.com/2000-20_4.html
On the home page you should see a
search tab just type in what you are looking for.
Tick in either the all software or
windows software box
IE: motherboard name audio driver
you might have to try a few times to get it right
for windows 7
Click start right click on computer
select properties then device manager scroll to sound and video game
controllers if you see a yellow question/exclamation mark or a red X the driver
will need to update drivers.
select properties then device manager scroll to sound and video if you right
click on sound and video then on high definition audio device select update
driver software.
Click start control panel hardware
and sound manage audio devices right click on your speaker select configure
speakers.
Right click on the speaker icon in
the bottom taskbar you will see an array of options select
playback devices make sure it
has a green tick and the correct speakers are selected
be updated if you computer came with
a motherboard disk the drivers could be on it although
once speakers are connected widows 7
should automatically update the drivers.
and sound manage audio devices playback you might have to set a default go for
via high definition audio then right click on speaker.
You
might have to configure them then select properties you will see tabs general
level in this tab make sure your settings are loud enough also enhancements and
advanced from the drop down list in the advanced tab select dvd quality or
another then apply
SOURCE: no sound
Try plugging a known good headset into the jacks behind the PC. Still no sound! Open control Panel, open Sound & Audio Devices. Click on the Audio tab. In the sound playback section a device should be shown. Click the Voice Tab, the same device should be there as well. Lastly, Open (System) while in control panel. Click the (Hardware) tab & than click Device manager. Scroll down to Sound, video & game controller. Do you see a yellow !. If yes there is a problem with your intergrated sound controller. You can try downloading & installing the sound drivers
for your PC at : http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=DIM_P4_4600&os=WW1&osl=en&catid=&impid=
If that still does not help than install a PCI sound card to your PC. Install the CD that comes with it.
