Title : E001 Error Code That is Not Resetable Error : paper jam
When the machine powers
up the E001 error code is displayed but cannot be reset. (Note: The reset
procedure for an E001 code is COPIER>FUNCTION>CLEAR>ERR)
Workaround
In this case, the Main Power Supply PCB Assembly was replaced. The machine
was powered up and the E001 code was able to be reset. The part number for the
Main Power Supply Assembly is FM2-0260-000.
Remember, if the fixing unit
circuitry has an open or a short, the code may not reset. Be sure to confirm
the fixing unit wiring and try resetting the code before replacing the Main
Power Supply Assembly. Canon USA, Inc. Systems & Technical Support
Division1-800-528-2830
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
