SOURCE: not recognizing new ink cartridge
We had the same problem and tried all steps Customer Service suggested each time; after several calls, it was determined we had a defective printhead... Kodak sent a new printhead, new ink cartridges w/ an envelope to return the ones I was using.
Apparently it's a common problem with this model; especially the earlier ones. Have had NO problems since the printhead was replaced.
I would suggest if you have recurring problems (even after Customer Service directives), call and ask if you might have a defective printhead.
SOURCE: Kodak Easyshare 5100 All-In-One Printer
The Kodak printhead is known to dry out. You can call kodak customer
service and complain your printhead is failling explain you have run
the printhead cleaning many times waisting your ink. They should ship
you a new printhead and free inktanks.
or if you dont want to wait on the phone....
I
have found lysol hand wipes to work wonders on the kodak printhead. I
have an ESP 5 and I have wiped the printhead with a lysol hand wipe
many times and it works like new. Here is a link to the product.
http://lysol.com/products/disinfecting-wipes/dwipes-4-in-1/
To wipe the printhead follow these instuctions.
remove
the printhead from the printer. put the tanks back into the printhead.
Be very carefull not to drop the printhead and do not put the printhead
on a table with the nozzle plate down (where the ink comes out). take
the hand wipe fold it a couple times. Gently wipe the printhead nozzel
plate in the direction of the lines on the nozzle plate do not do a
circular motion or wipe against the grain. you may not even have to use
a wiping motion. you can just place the wipe on the nozzles and let the
printhead soak. this will clear up dried up ink and unclog the nozzles.
put the printhead back into the printer run one printhead clean once to purge the ink and try to print.
I hope this helps.
I
used my printer to do a photo guest book at my sisters wedding it
turned out great (i wipped the printhead before i started all the
pictures look perfect!)
SDtester.
SOURCE: Kodak Easyshare 5300--Where do you buy printheads?
Please call 1.800.421.6699 and select option 01 for prints missing black or color ink. Kodak will send you a replacement printhead kit for free. I hope this helps.
SOURCE: kodak #G600 printer dock/roller won't pull paper through
I read this solution to a problem someone else was having which was similar to my problem. I wiped off the roller with a damp cloth, made sure it was dry and that's all it took to allow the roller to be able to start to pull the paper through. - thanks for the help!
SOURCE: Printer Kodak Easyshare 5300 Will not print black ink
just remove the head printer and wash with warm water and lett.t dry and replace.t
