This worked for me, but I have a Comcast Motorola DVD-R: These are the codes for your SONY SA-CT60 Audio Device. Follow the instructions below to program your remote. Most likely code: 30158 Others to try: 31758, 31759
To program your Comcast remote:
Turn on the TV or other device that you would like to program.
Press the TV button on your remote control. NOTE: If you would like to program your remote control to work with a DVD Player,
VCR or Audio device press the AUX button.
Press and hold Setup until the red light blinks twice, then release Setup.
Enter the first code for your device listed above. If you perform this procedure
correctly, the red light will blink twice. NOTE: If you enter an invalid code, the red light will display one long blink and
exit the programming mode. Repeat steps 2 to 4 with a valid code.
Aim the remote control at your device and press Power once (press the Play key for
devices that don't have a POWER button). If the TV turns off, make sure that the
VOL+/- and Mute buttons also work. If so, you're all set!
If not, repeat these steps using the next manufacturer's code (you may need to try
several codes to find the one that works).
You probably have the same problem that I found after I'd purchased my Viore TV (LC 26VF59), your cable box remote or dish network remote doesn't have the Viore codes built in. Bummer. I looked around and couldn't find codes for my Viore. Doubt you'll find them for yours. Here's a helpful suggestion I read about that works for me:
I bought for $20.00 a Sony RM-VL600 Easy Learn remote control from my electronics store. It's EZ because you only have to place the Sony head to head with the Viore remote, press TV setup and follow Sony's instructions to have its remote catch and learn the codes from your Viore remote. I only programmed my Sony for the Power On/Off, Vol Up/Down from my Viore remote. You back out of Setup and now your Sony will control the TV for those functions. Next you get your cable box or satellite remote put it head to head with the Sony remote, press the CABLE or SATELLITE set-up button on the Sony and then have it learn all the C or S functions you want from that remote. You do program in this mode the Power On/Off button, but you don't program the Vol Up/Down. The volume for the TV will work when you're all finished and operating under the Cable or Satellite button on the Sony remote.
Now, you press the TV button on the Sony and then the Power button. The TV turns on. Now you press the Cable or Sat button and then the Power button and the Cable or Sat box turns on. Like I said, even though now you are operating the Sony remote under the Cable or Sat button the TV volume instructions carry over to this side of the remote so you don't have to switch back to the TV button to raise or lower volume of the TV.
When I'm done watching, I hit the Power off and the cable box turns off. I then hit the TV button and again the Power off button and the TV turns off. So, it's a little inconvenient when starting and stopping, but at least you are using only one remote.
if you want to connect through cable , go on the net,
cable remote codes are 031,001,002,003,004,005,006,007,008,018,022,032,
and tv remote codes 001.
for the procedure go to sony programing technicail support on the net, a problem will be solved.
Press and release the device button you want to set up (TV,
VCR, Cable Box) However, if you are using AUX for a device, press and release
AUX first and then the device button for the type of device to be programmed
(TV, VCR, or Cable). The selected device button will flash once.
Release CODE SEARCH.
Press OFF/ON repeatedly until the device turns off (you
may have to press up to 100 times at a rate of once per second).
Once the device turns off, press and release ENTER.
With the device on, press
any other button. If the device responds, no further programming is required.
If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
Find codes for each device and brand below.
Press and "HOLD"
CODE SEARCH.
Press and release the TV, VCR or Cable button you want
to set up. If programming AUX for a device, press and release AUX first
and then the device to be programmed (TV, VCR or Cable). When the selected
device button flashes proceed to the next step.
Enter the three digit
code from the TV, VCR or Cable Box code lists.
With the device on, press another button, for example CHANNEL UP. If
the device responds, no further programming is required. If the device
does not respond, repeat steps 1-5 using another code number from the lists.
1. Turn on the device you wish to program.2. Press and hold CODE SEARCHuntil the INDICATOR LIGHT lights, then release CODE SEARCH. 3. Press and release the device button for the device you are programming (TV, VCR orDBS•CABLE). The INDICATOR LIGHT will blink once then remain lit. DVD codes are programmed under the VCR button.Note: For AUX, press DVD•AUXthen the device button you are assigning to DVD•AUX. 4. Press and release ON•OFF until your device turns off. Important: You may have to press ON•OFF up to 200 times. 5. When your device turns off, press the ENTER button, the INDICATOR LIGHT will go off
Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
