Question about Refrigerators
How do I remove the bottom grill from kenmore trio bottom freeze
Its a plastic grill that wraps around the front feet. How do I get it off without breaking it or breaking a finger?
    Sniper:
  • 56 Answers
The grill should pull off from the corners.
If the bottom of the grill is touching the floor, you may need to raise the front of the fridge before removal.
Posted on Apr 06, 2009
6ya staff
SOURCE:
When serging with stitch finger in, the thread wraps around it about 20 times causing a jam. What to do? Also, can I serge without the stitch finger in?
Don't know what machine you have. With my machine, I can pull the finger back a little so that the thread still wraps around it but is able to slip off the end of the stitch finger, ie do not push the stitch finger all the way in so there is no outlet for the thread. You can serge without the stitch finger, but it does change the character of the stitch, ie it may cause the fabric edge to buckle.
Jul 06, 2018 | Sewing Machines
Can't open bonnet on Ford Focus mk1 2001 any suggestions?
I just removed my front grill yep had to break it off, but easyly and neatly and use black tie wraps from b & q to put it back its just a cover nothing more folks use double tie put together to lenghen to your needs, on your bumpers at the either side near head lights there are plastic clips thread them through there and then place grill back through, a bit fiddly but it can be done, use pin nose pliers or tweezers to pull tie wraps back through and tie off.
Now the lock, mine was a swine, i gave it thought and thought and after really cutting me knuckles. found that where the housing is around the lock, the housing at the sides going to the back are plastic u just drilled these away to hole big enough to allow me to get a 10 ring spanner in and enough room ie cut more away if needed to undo the 2 bolts holding the lock in place, this way is easier and quicker by miles. i did the same on the other side i checked before doing any of this, and it does not matter as there is a black plastic cover over the latch you will this once open, that covers it all up. and you can,t see anyting once you put the grill back, try it i have some pics i will put on here so check mmm out, i tried for ages and i did it this way, you don,t have to its just a way to do it, it worked for me and i did my mates as well, and you can,t even tell.
Mar 31, 2013 | 2001 Ford Focus
External thermometre is not working where is this located
Normally most of them are located around the front of the vehicle near the front grill. It will be a small plastic sensor with either 2 or 3 wires going into it and nothing coming out of it. So look around the front grill and headlight area for something that looks like the tip of a larger permanent marker tip without the top on it and has wires connected to it. Hope this helps b
Nov 28, 2012 | Peugeot 406 Cars & Trucks
Water dispenser not working on kenmore trio refrigerator
The tubing inside the door is most likely frozen. Mine did that a year ago. I had to remove gasket and loosen screws around edge and allow to defrost inside door. There was a lot of ice around dispenser and tubing.
Sep 16, 2012 | Kenmore TRIO® 77553 Stainless Steel Bottom...
How do i remove a drip pan from a kenmore refrigerator
The drip pan collects water when the freezer goes into a defrost cycle. Most times there is very little water and the water evaporates quickly. When there is a problem with the freezer or the water does not evaporate between defrost cycles, the drip pan fills with water. If the front bottom of your refrigerator has a grille, you access the drip pan from the front. If there is no grille, access the drip pan from the rear.
Instructions
Rear Access
1 Unplug the refrigerator from the wall outlet. Pull the refrigerator away from the wall so that you can access the rear of the refrigerator.
2 Look under the refrigerator with a flashlight and locate the drip pan. Often when people install refrigerators they neglect to pull the packing from around the drip pan. The drip pan may have tape or styrofoam around it.
3 Remove any packing material away from the drip pan and pull the drip pan out from under the refrigerator.
Front Access
4 Pull the grille at the bottom of the refrigerator below the refrigerator door with your fingers. The grille secures to the refrigerator with plastic clips.
5 Remove any debris from the access area and throw the debris in the trash. The coils and fan under the refrigerator attract dust and dirt. Clean out the area with a lint brush if you have one.
6 Pull the drip pan out from under the refrigerator.
Apr 20, 2012 | Kenmore Refrigerators
How do I change the filter on the Kenmore 335?
According to the Owners Manual, here's what you need to do,
1.Turn the air cleaner OFF and unplug it from the power outlet.
2. Carefully lay the unit down on a flat surface with the Front Grille facing up.
3. Gently push in on Release Buttons on both sides of the unit, pull Front Grille out and away.
4. Remove and discard used HEPA filter.
5. Remove any plastic protective wrapping and from the new HEPA filter.
6. Set new HEPA filter into the air cleaner.
7. Install the Front Grille by engaging its tabs into the bottom slots on the unit. Then swing grille up and gently push in top to snap into place.
8.Turn the Air Cleaner upright and plug it into an outlet for
operation.
Hope this helped you. Please let me know. Thanks
May 04, 2011 | Kenmore 335 CADR Air Purifier
How do I remove cooling grille on my WTE86300BY/02? I don't want to break it. I regularly clean air cooler with warm water, taking it out through the maintenance flap. But I can see that inside the...
I had the same problem on a WTE8630SGB. There are six plastic insert/clips and I removed the grille panel by lying the machine on its back to get to the underside. Each plastic clip has three fingers and the middle one rotates to release - you are is supposed to be able to press the middle fingers one's lever arm - but it invariably breaks off before rotating enough to release - so i used a very fine screwdriver to prise the middle finger away from its release. One still snapped as the plastic is so brittle. Prise or rotate the bottom three and the top three hinge away. In my my 4 yr old machine there a little fluff build up on the impeller centre and on the (rather strange) cowl lining but on balance don't think it was worth the trouble of removing the grille!
Have fun
Alano, Chelmsford UK
Mar 05, 2011 | Bosch WTE86300 Electric Dryer
I have an LG LHD45EL dehumidifier. The manual shows removing the front grille to clean the coil by placing a hand on each side and pulling toward you. Mine won't budge and I'm afraid to pry the plastic...
I have the exact problem with my LG LHD45EL as lubbock51's Aug 17, 2010 question. (see below) Isn't there anyone out there that's had this same problem and resolved it. I too am afraid to pry the grill for fear of breaking it...it made out of plastic so it won't take much to break the grill if I did.
By lubbock51 on Aug 17, 2010
I have an LG LHD45EL dehumidifier. The manual shows removing the front grille to clean the coil by placing a hand on each side and pulling toward you. Mine won't budge and I'm afraid to pry the plastic in fear of breaking it. Any suggestions?
Aug 17, 2010 | LG LHD45EL Dehumidifier
Refrigerators Logo
481 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
