SOURCE: Ricoh CL7000 Pink bands
Hi there you have the magenta drum cleaning fault. You will have to replace the Magenta PCU (Photo Conductor Unit) 99.5% sure
Thanks J
SOURCE: Ricoh Aficio CL7000
If you have it connected by a CAT5 network wire, then the answer is no.
if you are using a usb 1.1 port on your computer to print to it, then that port is a slow port. I would recommend getting a faster 2.0 usb adaptor and using that port. It will print a little faster.
Steve C.
SOURCE: RICOH CL7000. SC372
You Have a cyan developer problem They come in kits which is the cheaper way to buy them. -Carl
SOURCE: Ricoh CL7000 text is blurry/fuzzy
probably only when printing in colour? Black only, is ok right?
It needs to have it's line adjustment procedure done. This is a series of complicated trial and error adjustments performed in service mode that the individual colours are adjusted based on printouts generated by the printer. Can only be adjusted by a service tech with experience with this adjustment.
SOURCE: Installed XP printer driver for Ricoh CL7000 5c
during the installation you have to select this option, by default the duplex option is not selected. Uninstall the software, restart your pc and install the software again, and select the duplexing option. I hope this helps
