My Maytag front load Dryer quit heating No heat at all just cold air, I was wandering if there is a reset button or can i replace a senser or element or something else. The Dryer isnt that old maybe a couple years old but not under warranty.
Ohm out the thermal fuse, if it is ok, then you can ohm out the heating element, be sure to visually check the element as well becqause it could just be shorted out internally giving you a reading, but first and foremost check your voltages be sure you are getting 240 across the outer plug spades and 120 volts from left to common and right to common, unplug this thing before you get into the element area or you could end up with a smokin fro !
