Cycling Logo
Posted on Apr 07, 2009
Unable to figure out how to inflate a bike tire
I purchased the Schwinn airdriver 1100 and I am unable to inflate my daughter's bike tire.
Some detail instruction with pictures could help
Thanks
Barbara
  • loriutset Apr 21, 2009
    I bought my pump at Target.  Unfortunately, it did not come with a manual.  I was unable to inflate our bike tires. I took apart the tip and now it will not go back together.
FIYxA
Level 1:
Passionate:
Visited the website for 10 consecutive days.
Habit-Forming:
  • Contributor 9 Answers
  • Posted on Apr 10, 2009
FIYxA
Contributor
Level 1:
Passionate:
Habit-Forming:
Answers
9
Questions
0
Helped
2041
Points
26
Could this help?
  1. Have the lever on the pump head pushed down, flat against the pump head.
  2. Push the pump head FIRMLY onto the tire valve.
  3. While still pushing firmly, flip the pump head lever up to lock the pump head onto the tire valve.
  4. Inflate to desired pressure.
  5. When finished, push the pump head lever back down and pull the pump head off the tire valve.
(Once you hook the pump up to your tire and start pumping, the back pressure will switch the flow to the bike valve output.)
2answers
I need to figure out what size tire and tube my Schwinn unicycle needs didn't have tire
Take the bike rim to a bike repair shop and they should be able to measure it and get you the right one. Most time if they see the make and model they can tell.
Troubleshooting guide
Are tires fully inflated? Is there any thing in the chain or around the chain? Suggest taking it to local bike shop
What is the air pressure or psi for a schwinn bicycle called discovery 700c
All tires have the maximum inflation pressure molded into the sidewall.Try inflating to about 5psi below the max as a start.(My 26" tires are "MAX INFLATION PRESSURE 65PSI",I like it at about 50psi.
I purchased a Schwinn bicycle pump, but I'm having trouble determining how to use it to inflate my standard bike tires. The instructions that came with the pump assume that I know the name of the type...
There are only two types - presta and schrader. If the instructions named them you could just Google them for descriptions and all kinds of other answers. The schrader is what we think of as the automotive style.
http://en.wikipedia.org/wiki/Presta_valve
http://en.wikipedia.org/wiki/Schrader_valve
Back to the search engines, "how to..." usually finds answers, such as "how to inflate a presta valve tube".
http://www.terratrike.com/media/documents/PrestaValve.pdf
http://www.youtube.com/watch?v=wreZho5I2E4
http://en.wikibooks.org/wiki/Bicycles/Maintenance_and_Repair/Wheels_and_Tires/Inflating_Tires
I just purchased a Schwinn "Safari" 16" boys bike
Why do you need the manual? It is more than likely a coaster brake bike, and a users manual is not going to answer any technical stuff anyway. If, you are concerned with the safety of it, go to a Schwinn bicycle dealer and have them check it out. Tire pressure is on the sidewall of the tire.
Dec 17, 2010 • Cycling
1helpful
SCHWINN AIR DRIVER 1100:HOW DO I USE IT TO PUMP AIR INTO BEACH CRUISER TIRES
SCHWINN AIR DRIVER 1100How do you assemble the air pump for bike tire
May 09, 2010 • Cycling
2answers
SCHWIIN AIRDRIVER 1100
you need to be a littil more in depth
Jun 26, 2009 • Cycling
12helpful
Instruction for schwinn bike odometer
find the circumference of the tire (measure the radius and multiply by 2 PI or 6.28) and convert it to millimeters--thats the number you put into the computer. I think you should get about 2154 mm depending on your tire inflation, but that doesnt make that much difference.
Top Cycling Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Tony Parsons
Tony Parsons
Are you a Cycling Expert? Answer questions, earn points and help others
