My washer fills up and then it stops and it smells like its on fire but its not....HELP!!!!
If the water fills up and starts have a burning smell, to me it sounds like the agitator motor is bad. Which would be the next part in the washing sequence.
That's the best I can make of the description
Appliance repair person would be who to call
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
SOURCE: washer does not fill
Firstly, check to see that your water temperature is selected properly. Next, check to confirm water supply to the washer is adequate, both HOT and COLD. If confirmed, try replacing the fill valve.
SOURCE: Kenmore 90 Series Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
SOURCE: Kenmore washer won't stop filling w/ water
The problem is most likely the water level switch. This would be the case if the water is able to be turned off with the dial on the washer and not running all the time.
If it is running all the time and you have to turn it off at the water line valve, then the problem is a stuck water fill valve.
If you need more help, post a comment.
You can find information on the parts at partselect.com.
You can buy parts from them or find them locally if you want.
Thanks,
Tim
SOURCE: Kenmore 70 series filled and stopped...
Lid switch problem. Press down on lid and try to start machine. Reply.
